2003 Harley Davidson FXDWG Dyna Wide Glide Logo
j
john Posted on May 09, 2014
2003 dyna changed stator rode 20 miles bike died. turns over but wont fire. The center pin at coil plug has power. BAS sensor has been wired around. I don't know if the CKP is going to have power on the red wire or if it creates power as motor is turning over. but there is no power on red or black wire while turning over.. I am lost
Will Tyrrell
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jun 21, 2014
Will Tyrrell
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
2814
Points
24
Do u have multimeter. If so check resistance of ckp. Sounds like that is tour problem. Why did you change out the stator
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Nov 10, 2008
SOURCE: change a stator
First secure the bike on a lift. disconnect battery.remove standard footpeg.Remove standard shifter. Remove all allen head bolts from outer primary cover. Some bolts are longer so keep track of where they go.Two bolts on the primary inspection cover also hold the outer to the inner primary case, so remove the cover.Now remove the outer primary case.The clutch,primary chain,adjuster, and compensating sprocket must be reoved as a single unit.Once you have done this take a rag and grasp the rotor and slide it off of the main engine shaft.Unplug the stator and remove the set screws holding it in place.Reverse procedure to install new stator.
Anonymous
  • 2712 Answers
  • Posted on Nov 20, 2008
Anonymous
  • 80 Answers
  • Posted on Jun 06, 2009
SOURCE: engine stalls after running for 25 miles?
Sounds like a fuel or intake problem to me, start the bike and spray brake cleaner onto the intake where it goes into the head, if the bike stumbles then you have an intake leak and have to change the seals or just tighten up the intake manifold. Another thing you could do is remove the carb (if it is carburated) remove the float bowl and clean everything including the jets, you could have some **** in there that is plugging things up. Also try removing the air cleaner and spraying a can of carb cleaner into and around the carb. Also try removing the gas tank and completely cleaning it and the petcock screen out, you could have something in the gas tank that is migrating to the petcock and causing a blockage.
aichare
  • 31 Answers
  • Posted on Sep 19, 2009
SOURCE: How to wire a tach on 05 heritage softail
Locate & route Black lead to ground / 2004-later softail: On the frame strap under the seat directly in front of the battery.
Locate & route the pink lead to Signal / For 2004 & later FXST/C/I The #3 cavity in the connector {39b} on the back of the speedometer. The socket terminal on the signal (pk) lead fits the #3 cavity.
Locate & route the Orange and white lead to power / Ummm.. it's saying for 2004 and later to adapt to the fuse block For earlier [ For 1996 to 2003 softail: locate the power lead (o/w) in the tail lamp pin connector {7a} under the seat behind the right rear corner of he battery.] "here you are looking to run it to a fused line, not directly to power/battery" I hope this helped.
Anonymous
  • Posted on Nov 10, 2009
SOURCE: need bacic wiring diagram ignition starter relays
i have a 2000 road king classic, last week i laid it down and the bike blew a couple of fuses, replaced them and the bike started, but i do not have any speedo lights and odometer, no power to the guage, also no blinkers, they light up but does not flash, also the right hand grip was rolled down, could this be the problem ?.
needing help
steven
Why would my 1998dyna wide glide harley just shut down after riding a while,i turn it off for 15 minutes, fire it back up and it just dies out?
overheating shouldn't be an issue. unless the pistons have been modified for hi-compression and inadequate octane is being used and it's being operated in high temperature region,i don't see an overheating issue. I have ridden these bikes in areas like death valley,las vegas and throughout the southwest and these engine won't heat enough to seize up. with ample fuel and spark during an attempted restart,the only reasonable possibility is your pick-up coil inside the cam cover. this inductive coil is in a heat sensitive area. this coil is mounted on a movable plate that affects timing. ,With adequate amount of fuel and a healthy spark you have all the ingredients of a start and run condition. this points to the direction of proper time and possibly a heat related condition. you may want to look into the pick up coil inside the timing cover. if it's original it has serve you well.While in this area,inspect the three wires attached to the pickup coil.
I have a 1990 kx 250, just had the top and bottom end done. Rode it for four hours and it died! Replaced the cdi box with new one, replaced the coil and stator and I still have no spark'
chec battery-must always be at 12.6volts-any lower and bike wont function--inspect connections for corrosion--also make sure carb and fuel delivery are correct
Jan 08, 2013 • Motorcycles
2001 Suzuki GSXR 600 starting trouble.
The stator is probably it..I had the same problem...After you change it the bike will run so much better. That's why it ran good with the new battery...Then it started draining it..It takes a special tool to get it out..
2answers
2003 Harley Davidson Dyna Wide Glide Not charging the battery
remove both ends of both cables and wire brush them shiney. Then reinstall (neg off first, on last). Try that first. If that does not help, start checking your other grounds around the bike. If everything is tight, try this:Step 1. First things first, load test the battery. Start the engine and measure DC Volts across the battery terminals, the regulator should be putting out 14.3 - 14.7 vdc at 3600 rpm.To check the regulator unplug it from the stator. Take a test light and clip it to the negative terminal of the battery and then touch first one pin and then the other on the plug that goes to the regulator. If you get even the slightest amount of light from the test light the regulator is toast. To do this with a meter which is more accurate: black lead to battery ground, red lead to each pin on the plug, start with the voltage scale higher than 12vdc and move voltage scale down in steps for each pin. Any voltage is a bad regulator.
  1. Unplug the regulator plug from the stator
  2. Start motorcycle and change Voltmeter to AC volts.
  3. Probe both stator wires with your meter leads.
  4. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. (Reading will vary depending on system, check service manual specification)
1helpful
I have a 2004 dyna wide glide and it will not start, i changed the sparkplugs and coil and still nothing
There is a tip over sensor called the BAS-Bank Angle Sensor, if it is engaged and malfunctioning the bike may not start, it may stall while running fine or while going around a curve or something like that someone I know had it malfunction completely and when a scooter goes down it may keep running beating the **** out of the rider, cause fire and other issues. I would recommend getting your BAS checked regularly by HD. You can google the BAS system and see thousands of issues with the BAS malfunctioning... That Harley denies having a serious malfunction with, but without witnesses and it malfunctioning in a gentle curve and the bike quits and riders are killed who is left to argue about the malfunction?
Stormi
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
