Question about Panasonic CT-32SL14 32" TV
No Power on 32" Panasonic
Followed your response recommendations. New 6.3 amp slow blow installed. Works great. Tried the 5 amp fast blow first. This did not work. I hope the slow blow doesn't hurt anything down the road.
  • Panasonic Master
  • 458 Answers
A slow blow fuse is also known as an anti-surge fuse the idea being any sudden "spikes" in you mains electric when you switch on would blow a quick blow fuse. Anti surge fuses are designed to tolerate any sudden initial electric pulse.
Posted on Jun 28, 2009
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
My philips tv flat screen keeps shutting off and a red flashing code starts blinking?
Not sure what code since you didn't say, but here is the code breakdown.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 27, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Red light flashing.set will not start up.
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 06, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
I have to unplug wait for the power light to stop flashing red multiple times before it will come on
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Sep 07, 2009 | Panasonic CT-32SX12 32" TV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
TI-84 Plus Silver Edition - Slow or no response
Blow in the i/o socket on top of the calculator. There's probably some dust stuck in it or something.
Mar 13, 2008 | Texas Instruments TI-84 Plus Silver...
Won't turn on
Follow AC cord in to clip-in glass fuse....replace with SLOW
BLOW 6.3 amp ( T-type) Panasonic factory correction...T.
Dec 19, 2007 | Panasonic CT-32SX31 32" TV
Panasonic CT-32SL14 32" TV Logo
227 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
