Question about Brother MFC-8640D Printer
Resetting change drum soon - Brother MFC-8640D Printer
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
6.Press Options.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Our fax machine starting displaying a message that said change drum soon...therefore i changed the drumand the toner itself but the message is still popping up.
Get out the operators book it will walk u through the steps on how to reset drum. Machine will still work ok with out resetting the drum counter.
Aug 13, 2010 | Brother IntelliFAX 4100 Laser Fax
What does drum end soon mean? Status monitor for my brother MFC-944)CN printer is saying Drum end soon! the file is being sent the status says ready, the paper goes through and comes out blank!
1. replace drum unit
2. after replacing reset the counter - press "3" and "9" button at the same time in the ready state, the reset menu will appear on the LCD, select "DRUM" and press "ok"
resetting without actual drum replacement might damage your printer.
Jun 29, 2010 | Brother MFC-9440CN Laser Printer
CHANGED DRUMAND THE CHANGE DRUM SOON ERROR IS
you need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Change Drum Soon still shows after changing the drum unit
After changing the Drum, open front cover and press "clear" then press "1" to reset.
Jul 22, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother PPF-2800 Fax Drum "change drum soon"
this it brother web side go there and will tell you how to do http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007573&Sympt=Why+does+the+display+still+show+CHANGE+DRUM+SOON+after+I+replaced++thedrum%3f&Model=61&ProductGroup=2&Keyword=change%20drum%20soon&ProductID=PPF2800
Apr 11, 2008 | Office Equipment & Supplies
Brother MFC-8640D Printer Logo
19 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
