Pulse h1012 driver - Audio Players & Recorders
1996 mitshubishi eclipse 2.0 non turbo. It runs but has no injector pulse on cylinder 3
Check for pulse about two inches back on the wires behind the plug. Wires tend to break at the plug. No pulse, you have to trace to the ECM, check there. If it is there run new wires to the injector. Not the, replace the ECM. A driver inside it has failed.
Aug 31, 2015 | 1996 Mitsubishi Eclipse
1989 caprice with 350 tbi injectors won't pulse anymore
If you have spark, the computer is getting the signal to pulse the injectors.
If you have power but no ground pulse, you may have fried the driver in the computer again.
You could get a used computer from a junk yard to test it.
There could be a short in one of the injectors or the harness at the computer, or a break in the circuit from the computer, and that could kill the driver in the computer.
Jan 18, 2013 | Cars & Trucks
2000 Dodge Grand Caravan only have two injectors pulsing?
I would check the wiring harness for the injectors
Should have 12 volts with key on-- to all injectors,same
as the ignition coils
Ignition or Injectors are turned on by PCM Drivers
Do not put any voltage to injectors they are pulsed
Dec 20, 2012 | Cars & Trucks
We have an optiPoint 500 system at our workplace and it is currently saying we are unable to record messages because the mailbox is full. Also, people say the phones are ringing but we are not getting the...
it.cc.stonybrook.edu/site_documents/.../guide_optipoint_500.pd
user manual
http://wiki.siemens-enterprise.com/index.php/File:Service_Manual_optiPoint_500_.pdf
Field service manual
If the mailbox is indeed full, and this WILL hold the entire system up, you simply need to remove the old messages. IF it is NOT true, then you have a fault,you need to first try a reset, and if that doesn't work, a re-program if that doesn't work, then the unit has developed an internal fault,and needs to be repaired.
wiki.siemens-enterprise.com/index.php/optiPoint_500
it.cc.stonybrook.edu/site_documents/.../guide_optipoint_500.pdf
Quick reference.
www.phy.hr/siemens/A31003-H1012-C121-8-7619.pdf
Please have a look at ALL links, all have good troubleshooting tips.
Apr 12, 2010 | Siemens Lands Phones
What would cause no fuel pressure and no injector pulse in a 1995 Dodge interpid with a 3.3 L
if your checking the injetctor pulse with a noid light ? then the reason for no pulse is the ECM! also would affect the fuel pump driver circuit if your just guessing theres no pulse/ ? then check the fuel pump at the connectors to insure theres voltage and the pump runs'
Jan 21, 2010 | 1995 Dodge Intrepid
I need a driver for my tangent pulse 1gb mp3 player ?! can u help ??
de unde iau si eu draivarul pentru acest mp3 tangent pulse?
Jan 20, 2010 | Tangent PULSE MP3 Player
1992 3.9 fuelinjector fuses?
under drivers seat to rear of 2 tin covered relays 1 for fuel pump 1 for pulse injetors and spark [must have twin contacts inside] if wrong relay you will either get spark no injector pulse or pulse injector no spark [had similar prob myself]
Nov 20, 2009 | Land Rover Range Rover Cars & Trucks
My virgin pulse need driver
I can't find my software for my Virgin MPF 1000 where can I get it?
Sep 11, 2007 | Virgin Pulse VP-MPF-1000 (256 MB) MP3...
Driwers for "Virgin Pulse VP-01"
Virgin Pulse  =  MPIO FY100
all soft seach on "http://www.mpio.com/downloads/index.php?search_part=FY100"
Jan 21, 2007 | Virgin Pulse VP-01 (64 MB) MP3 Player
 Grubhead
Grubhead
