Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
What could be wrong with my Ice maker?
I have tested voltage at N & L and only have 95v. I have tried jumper test at T & H to force a run and nothing happened. What next?
5 Suggested Answers
cresguy
  • 75 Answers
SOURCE: kitchenaid superba ice maker stopped working
the oil in the compressor has pumped up to the top hence the ice is not formed the lead valve in the compressor is not working properly so change the lead valve and you could make ice as before
Posted on Jul 25, 2008
heatman101
  • 43501 Answers
SOURCE: my ice maker does not
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Aug 19, 2010
livewire874
  • 618 Answers
SOURCE: Ice maker has lost power. I tested for power
There is an in-line fuse mounted in the line supplying the power to the ice-maker. It is in the wire clipped to the side /bottom
Posted on Oct 29, 2010
  • 5370 Answers
SOURCE: my ice maker in model
It can be possible that every thing needs replacing.But i think you are right,because the other possibilities has to be checked first to rule out the faulty ice-maker.First the tube has to be checked.The tube from which the water enters the ice-maker.The tube that enters the ice-maker may be filled with ice or the tube is got loose or the tube hose is got bit kinked towards its end. If so you need to remove the tube and get all of the ice out or check the fitting of tube and its condition and this should fix your problem. But if the tube is checked out perfect and there is no ice blockage in the tube then other possibility is the water inlet valve.There is a valve which lets the water to flow in the ice-maker.If this valve is faulty then it can be the cause of problem.The valve is at the back of the ice-maker unit.This valve has to be checked by meter.to confirm if its working or faulty.If the valve is also checked out ok then its quite possible that the ice maker is faulty.The ice-maker is controlled by the main board of the refrigerator.If all the other functions except the ice-maker are working then the board is working.And the problem is icemaker unit.----------This will help.Thanks.Helpmech.
Posted on Dec 02, 2010
Ice maker does not produce Ice motor running water on
ICE MAKER not making ice
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
God is the reason I give you free advice so God is good!
May 19, 2015 | Refrigerators
Ice maker not working
WATER INLET VALVE:
ICE MAKER ASSEMBLY:
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, should be replaced.
Apr 18, 2015 | Refrigerators
Water does not come out
Mar 25, 2015 | Refrigerators
My ice maker makes a loud whistling sound and stops producing ice with machine still running why does this sound occur and stop making the ice afterword and can it be repaired
WATER INLET VALVE:
Feb 24, 2015 | Whynter SNO ICE-100S 3 in 1 Portable Ice...
No water pressure or ice
ICE MAKER not making ice:
WATER INLET VALVE:
Jul 01, 2014 | Samsung Refrigerators
I am not getting water to my dispenser or ice maker. Model rf266arfs/xac
May 31, 2014 | Samsung Refrigerators
Is there a way to test the control module for my ice maker? The model number on the control module is W10190935. The ice maker is not getting any water. I have tested the water inlet valve and it is...
The ways to test the icemaker is of course have it installed into the i/m mold and connected to the plug in freezer to test it;
meter leads in the L&N holes on module should have 120 volts ac at all times,if not the thermal fuse on the wire from i/m module is blown, to test that the plug where the i/m plugs into should have 120 vac all times on the black and white wires in that plug from freezer wall into i/m
If 120 vac on L&N use jumper wire and jump the holes marked T&H,the i/m should start, may need to wiggle jumper till it starts,then you will hear click within 10 seconds remove jumper as soon as clicks, the im will rotate , if you think of fingers on i/m a hand on clock when the fingers are somewhere between the 10-12 o'clock area their should be 120 vac at water valve if 120 vac try again and plug water valve back in if no water fill when fingers are 10-12 o'clock water valve is bad
A WORD OF WARNING THOUGH IF YOU TOUCH A BARE WIRE ON JUMPER IT WILL SHOCK YOU,so only strip about 1/2" of each end of the jumper wire and bend into a U shape before inserting to jump i/m and wear nonconductive gloves
Good luck,
Gene
Aug 11, 2011 | Maytag Icemaker Motor Module Assembly...
Kenmore elite refrigerator 10652202101 small light by ice maker on off is red flashing and water dispenser doesn't work
There is a diagnostic code you can check first of all. The blinking light will indicate the type of problem that is happening. I have included a diagnostic chart for you. To check out the ice maker there are some test points on the ice maker module that can be jumped with a well insulated wire. I have also included a picture of the test points. Before starting any of the testing first unplug the unit from the wall outlet. You will need to determine if there is 120 volts present at the ice maker module, this will require a meter. If you have access to a meter and feel comfortable doing this type of testing check between terminals L-N for 120 volts. If there is voltage there next unplug the unit again and with your jumper now jump from terminals T-H. Plug the unit back in and if the ice maker runs, after a few seconds remove the jumper and watch it go through a complete cycle. If it fills with water at the end of the cycle then the ice maker will need to be replaced. If there is no water fill unplug the refrigerator again and jump terminals L-V. Plug the unit back in and if you get water now the will need to be replaced. If there is no water fill you will need to verify if there is voltage at the water valve in back of the unit with your meter. If there is voltage there replace the valve, if no voltage that will indicate there is either a broken wire in the cabinet or a poor connection in the ice maker harness. richroth_135.jpg richroth_136.jpg
Jul 21, 2011 | Kenmore Refrigerators
Clicking noise in freezer I am assuming to try to make ice, no ice being made?
Hi and welcome to FixYa, I am Kelly
Ice makers can stop ice production due to poor air flow though the evaporator coils or through the failure of the ice maker module. If your certain the clicking noise your hearing is from the ice maker itself here is are some steps that you can use to troubleshoot the ice maker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
This step from the above link is important:
TEST PROCEDURESIce Maker Plugged In To PowerShut-Off Arm Down-Freezer Cold
Test points L & N will verify 120 volts to Ice Maker module.(Make sure your test probes go into the test points 1/2".)
Test points T & H will verify if the bimetal thermostat is open or closed.
Short T & H with an insulated piece of wire ( 14 gauge) to run the motor. If the motor doesn't run, replace the module assembly. If you leave the jumper in for a half of a revolution, you can feel the heater in the mold heat up..if it's good.
Remove the jumper and the water valve will be energized in the last half of the revolution.
Once you insert the jumper between T & H touch the bottom of the ice maker and check for any signs of heat within the first minute. No heat = bad mold heater. It can 3 - 4 minutes for the sweep arm to harvest the ice.
Stick your finger back in the ice maker fill tube area in the plastic rectangular funnel area and check for ice build up. If the funnel is blocked with ice also pinch the ice maker fill tube for an ice block.
Should you notice ice in the funnel and the fill tube most likely the inlet water valve is bypassing water into the ice maker causing an over fill and ice build up condition. The remedy here is to replace the inlet water valve. They are NOT repairable. (Most of the time if the inlet water valve is bad your ice cubes will be fused into an ice block in the ice bin.) Also... if the ice maker fill tube is frozen full of ice... it can take up to 30 minutes using a hair drier to melt the ice as the insulation in the back of the freezer compartment keeps the ice maker fill tube from warming up enough to melt the ice in a timely fashion.
If you discover that the ice maker has over filled you can use a hand held hair drier and melt the ice in the ice maker.
If the ice maker seems to work fine then the freezer may be above 18 deg F. This is usually caused by ice build up on the evaporator coils as a result of either a defrost circuit problem or a slow running evaporator fan.
Thanks for choosing FixYa,
Kelly
Feb 20, 2011 | Maytag MBF2258HE Bottom Freezer...
Replaced water valve to ice maker -used jumper method on the ice maker to test - worked once then not again. checked the voltage coming in and it was 33 volts the ice maker also won't cycle with the jumper...
You need to replace the icemaker . Pt # 2198597 . When you open the freezer door . the laser flash 2 times , then pause , then 2 more times continually (normal) ? If the laser does not light at all , then icemaker is in the harvest mode ( may be stuck , replace icemaker ) . If in harvest mode , even slightly , jumper will not work .
Aug 29, 2009 | Refrigerators
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
20 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
