Question about Xerox WorkCentre 3220 All-In-One Laser Printer
Lsu motor error cycle power - Xerox WorkCentre 3220 All-In-One Laser Printer
How can i fix this message LSU motor error cycle power
That error is caused by a defective laser unit and would need to be replaced. The part number is 122N00276 and available below:
http://www.iteminconline.com/122n00276_122n00276-122n00297-xerox-3600-laser-scanner-unit-lsu.htm
Mar 08, 2016 | Xerox Phaser 3600DN Laser Printer
How do I fix power cycle error samsung laser MFP
Do you mean "Low Heat error - Cycle Power"?
If yes then you need to replace the fuser.
Otherwise give more details on the problem.
Jun 06, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Lsu motor error cycle power problem what can i do
Please change the LSU because the LSU unit is damage
May 05, 2014 | Xerox Phaser Office Equipment & Supplies
Engine LSU error printer model samsung ML2150
how can over come from LSU error problem in samsung all in one machines
Jan 21, 2010 | Samsung ML-2150 Laser Printer
LSU error
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Jan 13, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Error LSU
What you can do:
Jul 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Blank papers comes when the print given
D ear team, Blank papers comes when the print given. Meanwhile it shown the error msg is: LSU Hsync error cycle power pls give me the solution NHPC Ltd.
Feb 03, 2008 | Samsung ML-3051ND Laser Printer
Xerox WorkCentre 3220 All-In-One Laser Printer Logo
64 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
