Question about Motorola Walkie Talkie 2-Way Radio
How do you set them to work with other walkie talkies?
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions.
Get Support
Mark
Motorola Support
Posted on Jan 06, 2015
msmichalko
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
  • 1654 Answers
SOURCE: I'm searching for a User Manual Walkie Talkie T8550R Camo
I think you'll think this is fantastic: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
Posted on Nov 14, 2009
BillB-SA
  • 2761 Answers
SOURCE: i would like a manual for a technika TA-716walkie talkie
Tesco does not list operating manuals on their web site, so I suggest that you contact them directly by following this link:
http://direct.tesco.com/help/contactus.aspx
They should be able to provide you with the needed manual.
Bill B
Posted on May 03, 2010
Testimonial: "Thanks Bill. Much appreciated"
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
I have two identical kids walkie talkies with one speaker that doubles as Mic one works fine but the other one receives only it doesn't send anything I have tested with a third walkie talkie to confirm it...
If your radios have the feature called private line (aka PL, interference code, or code). It is possible the one radio which appears to receive only may have the code set to off (or zero). Check your user guide and see if you have this feature, then check to see both radios are set to the identical number.
If code is not the issue, you might want to try replacing the microphone from your spare unit,
Best regards.
Jan 21, 2014 | Radio Communications
Manual
where do I find the user manual for my spy gear long range walkie talkies model number 70437.
May 10, 2013 | Wild Planet Spy Gear Long Range Walkie...
Spy gear walkie talkie
Spy Gear walkie talkie????
You've not given me any other info, so how can I help you?
Please reply with the following info:
1. Make & Model of your radio.
2. Your question in regard to the radio, i.e,. THE PROBLEM WITH IT.
Unless I receive as much info regarding your radio, I am unable to give you an answer.
Cheers,
Peter
Mar 05, 2013 | Wild Planet Spy Gear Long Range Walkie...
Walkie talkies were working yesterday (gift from Christmas) and today the red power light is on indicating both working, but we can only get sound out of one of them.....any suggestions? brand new...
These walkie talkies are pretty simple to use. Turn on and turn the volume up and talk. So if you turn it on it is possible for there to be enough juice in the batteries to make the LED function but not enough to modulate (or talk) to the other walkie talkie. Have you tried to replacing the batteries with new ones yet? Sometimes recharge ables go bad and they are no good when you install them into your item. So make sure the batteries you installed are "new." And replace in both units. Should this not work, given the nature of the item and the age of those who will more than likely be using them, they break and soldier joints come loose. The back has a screw that is a specialty tool to remove. Outside of removing that and taking a look there is not much that can be done. Make sure to put at least 5 feet between the two radios to allow for good reception.
Regards, Tony
Apr 17, 2011 | Digital Blue LEGO Walkie Talkies
When i try To walkie-talkie it wont work
They do not have signal to receive the walkie talkie service. Try texting them and telling them to get in an area where they can get better service. Walkie Talkie coverage is very spotty.
Jun 24, 2010 | Motorola Mobility Boost i415 Cellular...
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
How do I make it work
It depends on the channels on the walkie talkies.
Can you supply the frz range of the TRC, and walkie talkies make and model and I will try and get the frez on the channels for you.
I can then tell if it will work or not.
Apr 27, 2008 | Computers & Internet
Radio Communications Logo
56 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
