Question about Linksys RangePlus WRT100 Wireless Router
WRT-100n driver download
I need to install the driver but I don't have the CD
How to enable bluetooth in bios setting in acer 4736Z?
HI...........................
Problem with the Mac Laptops How to enable bluetooth in bios setting in acer 4736Z?
SOLUTION NO 1:
Check your device manager first, if your Bluetooth driver not installed properly, then you have to installed it first. If you don't have that driver you can download it from internet. You have to specify the model no. of your laptop and Bluetooth after that you can download and install the driver and use your Bluetooth. If you find any difficulty in installing driver then there are web sites where you can find the whole procedure step by step.
SOLUTION NO: 2
I think you have installed a wrong driver or your driver has not been installed properly. You should check first in device manager for installed driver, if it is installed then you can see in a list below in that and if not then you have to install that first. You can download a Bluetooth driver for your machine from internet. You have to out your model no. of your laptop and you'll find it. After installing you can see the driver in device manager or it can also be seen in a icon near task bar.
SOLUTION NO: 3
Install the driver of your Bluetooth from a cd or download it from internet. After downloading install it in your system and it will work fine. If this does'nt work for you, then get an external Bluetooth it come with its own driver so you don't need to install it from internet. If you don't know the procedure of installation then follow the instruction in cd or online, it will help you in installation.
HOPE THIS SOLUTIONS IS HELPFUL TO YOU...................
GOOD LUCK.......................
Sep 24, 2011 | Computers & Internet
I have a Dell 924 all in one printer. How do I get it to work??
You Need to connect your printer to your computer with the USB cable.
Then Install the drivers from the CD which came along with your printer.
Follow the onscreen instructions while installing the drivers and software.
Once its Installed Start using your printer.
If you don't have the Driver CD, you can download it from the Internet.
Go to http://support.dell.com
Download the driver and install it.
Enjoy
Jul 12, 2011 | Dell 924 Photo All-In-One Printer
I don't have installation cd of lexmark x2450. how can i do it to install?
Any drivers you need can be found on the lexmark website. Note that some printers need the software installed before hooking up the printer. I'd try to install the printer first. The software will tell you if the printer needs to be connected.
Jun 13, 2011 | Lexmark Computers & Internet
Hi how can i set up my epson workforce 525 all in one on my computer without the installation cd?
You can download the software (the same as is on the installation CD) directly from Epson.
If you go to the following link, click ACCEPT and download and run the installation program, this will setup your printer on your computer.
http://download.ebz.epson.net/dsc/du/02/DriverDownloadInfo.do?LG2=EN&CN2=AU&CTI=59&PRN=WorkForce%20520&OSC=XP
Hope this helps.
Apr 15, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
Install without its cd
here is the download link:
click the mirror # 1 below
http://drivers.soft5000.com/dlf_3019.html
May 30, 2009 | Trust SpaceCam 120 Webcam
Fujitsu can not read the webcam
You need to install webcam drivers. Look for cd witch came with the webcam. Insert the cd, follow instructions to install webcam drivers.
If you dont have cd, post webcam make and model, i'll post the driver download link.
May 08, 2009 | Fujitsu AMILO PC Laptops
I have creative webcam vf-0040 and cant view the picture
 this is the driver you need and should work fine.
http://us.creative.com/support/downl...01_02_0729.EXE
Aug 22, 2008 | Creative Labs WebCam Live!
I lost my cd to install this cam, now i want to download a driver for it, but a don´t know where o how
Apr 23, 2008 | Trust SpaceCam 120 Webcam
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Good luck and kind regards.
Nov 24, 2007 | Linksys WRT300N Wireless Router
Linksys RangePlus WRT100 Wireless Router Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
