Question about Wolfgang Puck Dual Convection Oven With Rotisserie And Baking Drawer
BTOBR0010 replacement part - Wolfgang Puck Dual Convection Oven With Rotisserie And Baking Drawer
The heating element on my Hamilton Beach toaster oven 31134 has a hole in the covering and smells when I use it. Is that safe? Can I replace the heating element?
The element is failing and while it will probably not catch fire, it is better to be safe than sorry and just replace it. Does not look like a replacement element is offered. Sears has this toaster oven for $22.49 + $6.99 shipping.
Dec 10, 2016 | Hamilton Beach Toaster Ovens
HOW DO I GET REPLACEMENT PART #TO1313-02 for my Black & Decker toaster Oven #TO1322SBD? I purchased the oven 5/27/2013 and it has not worked for a couple months.
B & D doesn't sell replacement parts, and only warantees the unit for 1 year.
Sorry, but you will need to replace the unit. Thank the lawyers who told them it is too risky.
Jan 27, 2015 | Applica Black & Decker 4 Slice Toaster...
I have a Brevelle 800 toaster oven that starts, but does not heat up. What part needs replacing?
There is a thermal fuse that breaks power to the heating elements if it gets too hot (somewhere around 173 C. I replaced mine with an identically rated fuse and it was good for a week until I tried to cook twice in succession. I then replaced the fuse with one that trips at around 190C and it's been good for 4 months now. The fuse costs about $6 on ebay (shipping included) and takes about an hour to replace.
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Need replacement parts
Need replacement parts for the rotisserie on my module to241r. toaster oven.
Apr 22, 2014 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
The Breville BOV650XL will not power on.
I had the same problem with my Breville B0V650XL. It worked fine at breakfast, then wouldn't turn on the next time I tried to use it. Judging by the comments on this site, this appears be a common problem with this and many other Breville products.
I fixed my toaster oven by replacing the thermal fuse assembly. This part costs $4.39 on ereplacementparts.com. It's a shame that an expensive toaster oven is rendered useless by the failure of such a cheap part.
Replacing the thermal fuse itself is very simple - you'll need a small wiring nut and a phillips screw driver. Unfortunately, getting to the part requires removing the oven cover and about 40 screws. A long, magentic scewdriver is essential for parts of this job. It took me about 1 hour to fix my oven - two minutes to replace the fuse and the rest of the time to remove and replace the oven cover.
Feb 25, 2012 | Breville BOV650XL 1800 Watts Toaster Oven...
Top filament has burned out; does it pay to repair toaster oven or shouldit be replaced by a newer model??? We rarely use the oven and mostly use the appliance for toast. A replacement would cost less...
Chances are very slim your toaster oven is repairable anyway if the heating element burns out. A replacement part is not available, and there's no way to reliably repair a break. Even if it could be fixed, the low replacement cost makes it uneconomical. Parts and labor would run close to $50, maybe even exceed that price.
Unless you can find a part and do the repair yourself, small appliances today are throw-away items.
Jun 20, 2011 | Black & Decker TRO400 Toast-R-Oven Toaster...
The timer knob broke. I would like to get a replacement knob.
Go online and search up your exact model toaster oven and see if you can find a replacement parts website. If you can't, call or e-mail the manufacturer and have them send you a replacement.
May 18, 2011 | KitchenAid KCO1005OB 1400 Watts Toaster...
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Black & Decker Toaster Oven Model TR01000-TRO4000
I honestly believe that the burned element in my toaster oven is replaceable
like a burned out oven element or dryed element. I thought someone would
show me how to replace the element. That didn't happen. I am dubious
about the need for experts via a commitment to a specialists' plan.
Peter Olevnik
Dec 15, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Panasonic Infrared Bulb Replacement
Ordered a Heater, part #ABA83-148-0U from www.partstore.com - per the advice on this website.
May 09, 2008 | Panasonic NB-G100P 1300 Watts Toaster Oven...
Wolfgang Puck Dual Convection Oven With Rotisserie And Baking Drawer Logo
Top Wolfgang Puck Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Wolfgang Puck Toaster Oven Expert? Answer questions, earn points and help others
