Question about GE Nautilus 24" Built-in Dishwasher
Dishwasher drains but leaves behind about 1/2" of standing water
On a similar GE Nautilus all black washer, it will drain the water out, quickly but when the cycle is over, it leaves behind about 1/2" to 1/4" of water that just covers the area where the filter/screen is on the bottom. I've pulled the hose going to my garbage disposal, put it in a bucket and turned it on to a drain cycle and it will drain about 1.5 gallons of water in a matter of seconds. It doesn't appear that there is a major blockage but I'm not sure what is causing the residual water.
  • 3 Answers
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Posted on Jun 28, 2009
GE Nautilus dishwasher doesnt drain
Water dosent drain Is there a reset button???
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
After I run the dishwasher, water stands at the bottom and it smells. I have had the dishwasher for five years. The washer seems to be working properly it's just that water stands at the base of the...
no it's not normal, you are probably having some cloge in the drain pipe, you could try with a pice of wire to pick it up or hose it down, or use some comercial unplaguners like mr. muscle or something like that, i think that this would do the trick
Oct 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Aug 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not drain (water just trickes out) fill is good
Drain valve not opening or pump impeller loose on shaft - is it washing ok?
My guess would be drain valve not opening. It is a 110v solenoid and they get stuck or burn up. New solenoid costs ~$20.00
Mar 26, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Older portable dishwasher
nothing it needs a switching kit or drain solenoid kit rather
Dec 30, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Drain
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 04, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus ...
Does water drains out properly ?
May 02, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Nov 14, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
785 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
