Question about Sony Playstation 3 (PS3) Console
When turned on it will start up for a second then turn back off
Will start up, then turn right back off and beep 3 times. I tried to hold the on button for 15 seconds but that did nothing.
This sucks!
  • iansyfz Jun 23, 2009
    Well I was able to get my game out the ps3. While holding down the eject button then turning the switch on the back to on, it ejected my disc, then it turned the fan on turbo mode then shut off
    I still cannot get the PS3 to turn on though, or play a game.
    The ps3 has well over a foot of room in any direction from it. It also sits about 3-4 high off the ground on a glass shelf.
  • 49 Answers
Turn the power on and then hold the power on button for 10-15 seconds. If this doesn't work turn it off and then back on in the back and try again this is all I can suggest.
Posted on Jun 22, 2009
  • jnewton1987
    jnewton1987 Jun 23, 2009
    Ok well tell me how much space does it have from walls and windows and the floor? This stuff might be due to overheating which is also common. If this is the case give the PS3 enough space to breathe, 11cm for each side, especially the vent in the back, which prevents it from becoming hot. Let me know how this does for you.
When i turn on my ps3, the green light stays on and the tv screen doesn't even change. i changed the cords to make sure the audio/video wasn't just out. i tried to enter 'recovery mode' but it won't even...
If you have a "slim" ps3, it does not beep 3 times. Try this.
First, with the system off,plug in your old red, white, yellow cables into the tv. (make sure your tv is on the correct setting). Now, just turn on the ps3 the regular way. Did you hear the sounds it normally makes when booting up (the ps3 boot music?). If so, thats good. If you did not, check again that the tv is on the right channel, and if possible, try another set of red, white, yellow cables.
If you heard sound, but do not get a picture, turn the ps3 back off. After the red light comes on, hold your finger down on the power button for about 5 seconds. If you have a fat ps3, it will beep 3 times after a few seconds to get back to regular tv mode. If you have a slim ps3, it will beep once, then 1 more time a few seconds later. It should reset and turn back on. If your tv is on the right channel and the cables work, then you should now see a picture and you know your audio/video is working. You can now try your HDMI cable and it should prompt you to use the HDMI at this point.
Hope that helps.
Mike!
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
PS3 Discs Not Loading.. (Dvds, Cds) We Opened Up The PS3 And Checked The Drive And Cleaned The Lens And Dusted Off Everything Pretty Much And We Put It Back Together And turn it on Still Not Working Jus...
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Dec 31, 2010 | Sony Playstation 3 (PS3) Console
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    I tried to turn on my playstation 3 and all i see is a black screen. This happened about 3 times and we just got it. Should we return it? or is there a way to fix it?
    Ok try this first, it may be a video setup problem :
    Step 1. Turn the PS3 off into standby (red light on)
    Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
    Step 3. Wait for your PS3 to start.
    This solution basically resets the video output back to standard definition. If this does not solve your problem then you need to take it back to where you got it from.
    Hope this helps and thank you for using FixYa
    Sep 01, 2010 | Sony Playstation 3 (PS3) Console
    Play station is hooked up on turned on (blue light) tv is on and on the right input but nothing shows up on the screen. Please help
    Please try these easy steps to sort your problem out :
    Aug 23, 2010 | Sony Playstation 3 (PS3) Console
    HAS A BLANK SCREEN WHEN POWERED ON AND NO SOUND
    i got this from getupart from this site and he/she said....
    1. Turn Off in back (wait few seconds for it to re-set)
    2. Turn on in back
    3. Turn on in front and hold your finger on it 'till it turns off again -
    (you get the beep on then the three beeps for reset and it will eventually beep again and turn off)
    4. Turn off in back (wait few seconds for it to re-set)
    5. Turn on in back
    6. Turn on in front hold finger for three beeps and damn it works!
    Apr 27, 2010 | Sony Playstation 3 (PS3) Console
    The component cable is hooked into the tv and its on the right channel but the ps3 doesnt show the display screen
    Try the following easy steps :
    Dec 04, 2009 | Sony Playstation 3 (PS3) Console
    Nothing comes up on tv when i turn ps3 on and controllers wont connect
    Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
    Nov 07, 2008 | Sony Playstation 3 (PS3) Console
    Playstation 3 problem
    Try holding the power down for 10 seconds while the red standby light is on. It will beep a couple of times. It should reset your video display settings.
    Jul 25, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    104 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
