WD-80264NP problem code UE - Washing Machines
3 Suggested Answers
bayyagg
  • 1672 Answers
SOURCE: i have an lg 5kg washing machine WD-80264NP which
Ur timer switch for washing/spinning is broken, there are contact points on that timer switch, the part of SPiNNiNG is not functioning!
Let a technician check on that, and might as well replace it!
Posted on Nov 29, 2010
  • 6277 Answers
SOURCE: what is OE in lg
Sorry but I do not know your particular machine but on some models it means 'no drain'.
So- here are my generic/general guidance notes ;-0)
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 19, 2011
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
May 15, 2012 | Washing Machines
I have an lg 5kg washing machine WD-80264NP which stops after washing for while.it doesn't spin. what could be the problem?
Nov 29, 2010 | LG Washing Machines
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
May 16, 2010 | LG WM1814CW Front Load Washer
Ue error code on my LG WASHER
Hi there
hope this helps you .
UE - Unbalance switch error Unbalanced load is sensed three times during a spin operation. Open lid. Rebalance laundry load and close lid.
· Check wiring harness
· Check unbalance switch
· Check circuit board thank your for writing to fix ya.
Best regards Rich
Dec 08, 2009 | LG WD-16115FD Front Load Washer
I have an LG washer dryer (model 12126rd) and it has just cme up with either UE or VE on the frint LCD panel. What does ths mean? Thanks!!!
UE means imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Resolution: Move the washing around inside the washing machine to create a more even distribution of weight
Oct 25, 2009 | LG WD-12126RD Front Load Washer / Dryer
Error reading
An UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum
If you tried out all things and it did not work,
then I would say you have a bad motor. The motor has a tach in it that tells the control board if the load is balanced. If the tach is bad in the motor then it will always think the load is unbalanced.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | LG WD-1045FH Front Load Washer
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Sep 23, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
