Question about PfaFF Sewing Machines
Hobby 1016 made clunking noise then needle stuck in down position and will not move
  • 66 Answers
SOURCE: I was given a brother
Hey RM check the bobbin area and see if the hook area has any thead cought in it you might have to remove the bobbin case to see it
Posted on Jan 30, 2009
SewTechWayne
  • 186 Answers
SOURCE: Brother Innovis 4000 D stopped sewing
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
bargainbox
  • 1388 Answers
SOURCE: Need threading instructions for pfaff hobby 1016.
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines. HERE
Best Wishes Martyn
Bargain Box in Australia
Posted on Sep 10, 2009
  • 632 Answers
SOURCE: Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Posted on Jan 05, 2010
  • 632 Answers
SOURCE: Have a PFAFF hobby 1016 with no instruction book.
PFAFF Manuals
Why does it make a knocking noise as it sews?
the needle position is up tight in the holder and no where else
the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
from your description and what you did, the needle /hook timing needs adjusting as it is out
turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
tighten up the screw
next is to check the needle tension is not too tight
workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
May 12, 2016 | Singer Stylist 7258 Electric Sewing...
Needle 1/ was working ok then a noise had to power down, Now it will not let me do anything just keeps telling me to power down all the time. it is a vicious circle. any cluesTh
you may have knocked it out of time. when you heard the noise it might have been the needle hitting the fabric to hard which can sometimes knock your machine out of time. you may have to find a local sewing machine store that fixes machines. if you find one they should be able to repair it for little to no cost.
Jan 10, 2015 | Janome MB4 Four Needle Embroidery Machine
Brother cs 5000h is totally jammed, hand crank won't turn, needle stuck in down position
I would totally remove the bobbin apparatus & check that area
Oct 09, 2017 | Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
My brother started making a loud noise when sewing pant fabrics
Your machine is complaining because it doesn't have the power to push through the layers of fabric. That clunking noise is the gears in the machine skipping and being sheered off (or it will be eventually) STOP!
If you feel that you need to continue... stop when it does this noise and use the HAND WHEEL. You'll also need to make sure that the presser foot remains level while going over thick seams.
Jan 02, 2013 | Brother Sewing Machines
My brand new machine Brother PC 420 is making a clunking noise as the needle moves as if the timing may be off? What is this?
Make sure that your needle is inserted all of the way up, maybe even install a new one, just to be sure. Recheck your threading, with presser foot up, pull top thread, should pull smoothly, now put the presser foot down, pull again, should barely move. If, you are sewing on a bare table, try putting a bath towel under it. If, noise continues, return it and get a new one.
Nov 05, 2010 | Brother PC-420
How do I adjust the needle shaft position on my Hobbylock 788. It somehow shifted up.
take the end cap off and follow the needle bar up until you see a block with a screw in the middle of it.bring the needle bar down useing the handwheel to its lowest position loosen the screw and you should be able to move the needle bar if you have a needle threader you can use it to reset the height of the needle bar just bring the threader down and then lower the needle bar to where the threader fits into the eye of the needle like it would if it were being threaded
Jun 30, 2010 | PfaFF Hobby 4260
Dec 30, 2009 | PfaFF Sewing Machines
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
