Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My Mitsubishi WD-52525 is only showing black and white rectangles on the screen. I hear sound, but there is no picture.
    Problem Solver:
  • 4 Answers
Check the white rectangular ceramic fuses on the FMT board. You blew one of them so there's power missing to some of the circuitry.
Posted on Jun 25, 2009
  • 668 Answers
The Format board is the problem. The only cure I know of is to send the Chassi Assy. to Mitsubishi for refurbishing. The Format board is not available per Mitsubishi so you hand is kinda tied. Call Mitsubishi at 18003322119 to get a local servicer to help you out. It will not be a cheap repair. Probably around 800.00 to 900.00.
Hope this helps,
Skyassoc
Posted on Jun 23, 2009
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a mits wd-52525 i got it from my neighbor, he said it needs a new screen,but the outside looks fine, i hear glass when i move it, someone said the mirrors are broke.could there be anything else, and...
the mirror is a single unit and can be purchased from mitsubishi however you will probably have some scratches in the optics eye and this will show in your picture
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Black Screen with White Randomized Pixels
Bad FMT (Formatter) circuit board. No longer available for purchase from Mitsubishi.
The electrical chassis will need to be sent to Mitsubishi for rebuild.
Wait time: 4-8 weeks
Cost (including labor to uninstall it and reinstall it: $800 +)
Nov 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
Oct 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sound but no picture
Good Day, gary;
It sounds like the TV has a bad formatter board. This board is not available from the factory, it must be repaired. Tile or block pattern with no video or OSD. Check D8F00 and D8F01 part # 264P828010, also check C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002). Remember FMT PCB is not available. Good Luck, Big Irish.
Jul 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Black and White rectangles, no picture just sound
Need a little more info on your problem. My crystal ball is not working at the present. You need to tell us more about where these rectangles are, how are they spaced, when they are there. Do they move around or change colors. Give as more to work with here.
Aug 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
