Question about Matrix T3Xi Treadmill
A2 is coming in my matrix tredmill what it mean
Unable print error A2
Error A2 means Document is too long.
If you wish to get some details about printer repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 21, 2016 | Brother MFC 9840CDW Color Laser...
Wont heat up enouf
Robin,
Do you mean the car isn't coming up to temp or you can't get enough heat from the heater? If the heater, there could be several sources, lack of hot coolant circulating through the heater matrix due to a bad valve, kinked hose or blocked matrix. It could also be a problem with air routing around the matrix.
You haven't identified the make and model so had to be more specific.
Jan 02, 2015 | Cars & Trucks
Smell like something is burning
It means ur Belt is starting to rip and it It is probably getting tangled
up in the motor so it burns and smells or something is in the tredmill like a blastic bag or something so I would look at that
Aug 29, 2013 | Weslo Cadence 450 Treadmill Walking Belt
Definition of special product in algebra types and example of special product in algebra
Product means the result you get after multiplying.
In Algebra xy means x multiplied by y
Likewise when you see (a+b)(a-b) it means (a+b) multiplied by (a-b), which we will be using a lot here!
Special Binomial Products So when you multiply binomials you get ... Binomial Products
And we are going to look at three special cases of multiplying binomials ... so they are Special Binomial Products.
1. Multiplying a Binomial by Itself What happens when you square a binomial (in other words, multiply it by itself) .. ?
(a+b)2 = (a+b)(a+b) = ... ?
The result:
(a+b)2 = a2 + 2ab + b2
You can easily see why it works, in this diagram:
2. Subtract Times Subtract And what happens if you square a binomial with a minus inside?
(a-b)2 = (a-b)(a-b) = ... ?
The result:
(a-b)2 = a2 - 2ab + b2
3. Add Times Subtract And then there is one more special case... what if you multiply (a+b) by (a-b) ?
(a+b)(a-b) = ... ?
The result:
(a+b)(a-b) = a2 - b2
That was interesting! It ended up very simple.
And it is called the "difference of two squares" (the two squares are a2 and b2).
This illustration may help you see why it works:
apb-amb-why.gif a2 - b2 is equal to (a+b)(a-b) Note: it does not matter if (a-b) comes first:
(a-b)(a+b) = a2 - b2
The Three Cases Here are the three results we just got:
(a+b)2 = a2 + 2ab + b2 } (the "perfect square trinomials") (a-b)2 = a2 - 2ab + b2 (a+b)(a-b) = a2 - b2 (the "difference of squares") Remember those patterns, they will save you time and help you solve many algebra puzzles.
Using Them So far we have just used "a" and "b", but they could be anything.
Example: (y+1)2
We can use the (a+b)2 case where "a" is y, and "b" is 1:
(y+1)2 = (y)2 + 2(y)(1) + (1)2 = y2 + 2y + 1
Example: (3x-4)2
We can use the (a-b)2 case where "a" is 3x, and "b" is 4:
(3x-4)2 = (3x)2 - 2(3x)(4) + (4)2 = 9x2 - 24x + 16
Example: (4y+2)(4y-2)
We know that the result will be the difference of two squares, because:
so:
(4y+2)(4y-2) = (4y)2 - (2)2 = 16y2 - 4
Sometimes you can recognize the pattern of the answer:
Example: can you work out which binomials to multiply to get 4x2 - 9
Hmmm... is that the difference of two squares?
Yes! 4x2 is (2x)2, and 9 is (3)2, so we have:
4x2 - 9 = (2x)2 - (3)2
And that can be produced by the difference of squares formula:
Like this ("a" is 2x, and "b" is 3):
(2x+3)(2x-3) = (2x)2 - (3)2 = 4x2 - 9
So the answer is that you can multiply (2x+3) and (2x-3) to get 4x2 - 9
Jul 26, 2011 | Computers & Internet
What does e01 mean on a tredmill?
error 01 var fctb_tool=null; function FCTB_Init_9ca4cf8dddd44654bf538c9ee2a551bb(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_9ca4cf8dddd44654bf538c9ee2a551bb(document['FCTB_Init_0dde2bb1d3294205889a4a3a8539a897']); delete document['FCTB_Init_0dde2bb1d3294205889a4a3a8539a897'] var fctb_tool=null; function FCTB_Init_7ce68d65cfd643589a9add54ad09ffb9(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_7ce68d65cfd643589a9add54ad09ffb9(document['FCTB_Init_1d78963a8d054bb1a1d0dcc13663fe1c']); delete document['FCTB_Init_1d78963a8d054bb1a1d0dcc13663fe1c']
May 05, 2011 | Sport & Outdoor - Others
Error E07 on Carl Lewis Treadmill
does any1 know how to fix the e07 error on the carl lewis tredmill or why is has appeared?
Feb 06, 2011 | Sport & Outdoor - Others
What means A2 on the dashboard
A indicates oil change is due and 2 indicates engine and cabin air filters are due.
Oct 12, 2009 | 2005 Honda Odyssey
How can I create PVCs on 6381-A2-200?
I mean that PVC is "private virtual circuit".
May 21, 2008 | Paradyne (6211-A2-200) Router
Tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Formular to show number and cell references
The formula for A1 is: =SUM(B4,B5)
A2 is: =SUM(C4,C5)
A3 is: =SUM(A1:A2)
To test this, put 25 in cell B4, 25 in cell B5, then 30 in cell C4, and 30 in cell C5.....the result in cell A3 is 110.
Hope this helps.
Mar 07, 2008 | Microsoft Excel for PC
Matrix T3Xi Treadmill Logo
Top Matrix Exercise & Fitness Experts
David Payne
David Payne
Sportsmith LLC
Sportsmith LLC
greg kinsley
Are you a Matrix Exercise and Fitnes Expert? Answer questions, earn points and help others
