Question about Honda Air Tools & Compressors
Gas air compressor shuts off when using air tools
2 Suggested Answers
  • 8404 Answers
SOURCE: how to fix compressor air gas 55 hp dewalt it
that is probably the top end for this machine. If not sure, visit the web site of the manufacturer.
Posted on Oct 10, 2009
Compressor has air coming out the air in take, and has air pressure in the crankcase. When shut off. I shut it off at 150psi.
home compressors should cut out at 100- 110 psi so check / replace the controller
air out of the inlet is air under pressure holding the valves open
pressure in the sump is a blocked breather for the sump possibly from excessive air pressure
remember it is not pressure that drives tools but volume flow so if you have a 10 cubic ft /min compressor but are running a tool that requires 12 cubic ft /min air then 150 psi is not the answer
a bigger capacity compressor is
Nov 06, 2016 | Air Tools & Compressors
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
Cummins industrial tools air compressor
Lack of oil or sufficient power is typically why a compressor will shut off. or a bad pressure gauge.
Dec 03, 2013 | Air Tools & Compressors
My 185 ingersoll rand tow behind compressor shuts down when I open the valve to blow out sprinkler system...why
I worked at a tool rental store while attending college and noticed that IR compressors would shut down for a variety of safety reasons. Most common was low oil (engine), high temp (engine) and high air temp (compressor) and safety valve measuring access flow or free flow as if the hose becomes disconnected from tool (OSHA safety). Check all the safety control features of your unit for possible answer. Good luck
Oct 12, 2010 | Ingersoll Air Tools & Compressors
Craftsman air compressor 2 hp 20 gallon, seems to running o.k. builds up to 100lbs shuts off when it hits 80lbs come back on, but when i run a tool , right around 90lbs the tool dies out and runs week.when...
IT depends on the tool. Some tools require higher cfm. (cubic feet per minute) of air. IF your air line is not large enough, then sometimes 90psi is not enough to operate a tool as there is a pressure drop at the tool. Look at the required cfm for each tool. Find a chart for air line size, cfm and pressure. Most impact wrenches should be used on a minimum 3/8" air hose. You could look at your manual and see what the max pressure is on your compressor. You may be able to decrease the differential pressure e.g off and 100 and on at 90, but then the compressor will cycle more frequently, and may exceed the duty rating of the compressor.
Oct 01, 2010 | Craftsman Air Tools & Compressors
I HAVE A 4 HP GAS COLEMAN POWERMATE COMPRESSOR. THE COMPRESSOR KEEPS RUNNING AND WONT SHUT THE PRESSURE OFF UNTIL THE BLOWOUT VALVE BLOWS.THIS COMPRESSOR HAS A HONDA 4 HP GAS ENGINE ON IT.THE PRESSURE IS...
Coleman PowerMate CT4090410 Operator Parts Manual
This unit uses an loader valve to control pressure, it will unload compressor and idle engine back until the pressure falls below 95 psig and the speeds engine up and loads compressor until cutout pressure is reached. I've linked to manual and the unloader is
Coleman PowerMate CT4090410 Operator Parts Manual Page 18
The item number is 9 and part number is 070-0056.. This part is around $100-$110. Ive repaired this type part on air compressors used on mechanics service trucks ., Depending on your skill level and access to tools and parts, it might be better to purchase a new one.g take time ti read to read and understand manual. Good luck
Nov 10, 2017 | Coleman Air Tools & Compressors
I have a bostich/Textron CWT 30A oiless air comp 3/4 hpseems to be sucking air and blowing at same time..very low pressure output also.tank is not filling up & shutting off
most likely need new piston and sleeve kit or could be just needs new valves.these oilless compressors are ok for very lite use but if you run them hard they wont last
Aug 22, 2010 | Stanley Air Tools Compressor 16pc...
The compressor turned on pumped up and shut off and wont start up
Inccrease the line pressure to 90 PSI, a air ratchet is a very high volume air tool and the compressor may not be able to keep up with it.
Jul 14, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How much power (kw/hr) does a D55152 use at full capacity?
Below you will find the power requirements for your compressor. I would recommend not to use an extension cord due to possible damage to capacitor. My dewalt a/c, with same motor, is actually using 17.5 amps right before shut off. Good Luck!
  • Drive: Direct
  • Horsepower: 2.7 MAX HP
  • Tank Size: 4 gal
  • Power Supply: 120V AC, 15 amps,
    >60 Hz, 2 pol induction motor
  • CFM @100 PSI: 3.8 CFM
  • Pump Speed: 3400 rpm
  • Tool Length: 18"
  • Tool Width: 18"
  • Tool Height: 16"
  • Tool Weight: 65 lbs
  • Oct 15, 2009 | Dewalt Heavy - Duty 1.1 Hp Continuous 4...
    Air Tools & Compressors Logo
    Top Honda Air Tools & Compressors Experts
    John Trevino
    Renee Knafel-Bullock
    Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
