Question about HEALTHRIDER Exercise & Fitness
How fix grinding sound healthrider r60 treadmill
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Posted on Jun 28, 2010
How do you check actual mileage on a Healthrider r60 treadmill?
I dont believe it is possible. Not many brands worldwide give you this option.
Jan 02, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
Set at 4mph. will climb to only 3.7 mph will get to 4 mph if set at 4.3 mph. will not attain setpoint speed and shuts off at 4.0 mph or above.
please RUN the software calibration for diagnose, troubleshooting and fix it. You have a speed sensor bad adjust it. clean it and tigh the wires connector very well. b) LUBE the shaft and gear from elevation motor c) adjust the pot.
God bless you
Jul 26, 2012 | HEALTHRIDER R60 SoftStrider Treadmill
Where can i get a new key for my treadmill
go to www. fitnessrepairparts.com or www. doctortreadmill.com
www. treadmillpartszone.com
God bless you
Jun 13, 2012 | HEALTHRIDER R60 SoftStrider Treadmill
Incline motor stays on going down, and will not respond to the controls. healthrider R 60
could be bad incline sensor or c/board is going bad. one more try bipassing the board with power to the incline motor fully powered 18volt batt will or higher will move the motorby flipping thr wires on the bat the incline should go up and down. if working ok then check board
Mar 16, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
Healthrider r60 stops when it reaches 4mph.
Jun 28, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
Exercise & Fitness Logo
23 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Techmotionusa.com
Techmotionusa.com
greg kinsley
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
