Question about Smeg Washing Machines
Where can I get a venting kit for a hOmebase portable air con unit model H253797
Does any one know where I can get a venting kit got this model please.
  • 86 Answers
SOURCE: through the wall HAIER air con
model no
capacity of a/c
need to solve yr problem
Posted on Mar 17, 2008
SOURCE: RADEL CR 208 PORTABLE AIR CON UNIT
DOES ANYONE ACTUALLY ANSWER ANY PROBLEMS ON THIS FORUM?????????????????
Posted on Sep 21, 2008
ghost45
  • 1280 Answers
SOURCE: Air con hissing noise from vents
Strongly suspect the AC system has sprung a leak somewhere and the refrigerant is 'low' - the 'hissing' noise you hear is normal when the system is 'undercharged.' Solution is inspect the system & repair the leak. If it turns out there is NO leak, then the problem is either at the compressor (low head pressure) and/or the expansion valve at the evaporator.
Posted on Sep 07, 2009
wise_jf
  • 66 Answers
SOURCE: wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
Posted on Jun 30, 2010
  • 586 Answers
SOURCE: I need to know how
Hello there,
For you to be able to use the homebase as a dehumidifier only, try to download the user guide from the link below, fill out the information on the form and follow the rest of the instruction from there:
http://mail.manualstock.com/search.php?cmarque=HOMEBASE&modele=H275937
Hope you find this information helpful. All the best. Elect_Comp
Posted on Sep 08, 2011
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
Exhaust Heat
There is a kit for that. You can also import outside air instead of using cool air from the room. You can make or find "small kitchen pan" that covers the intake area on the back then add a collar for a 4" hose from a dryer and vent it outside making sure the air stays away from the exhaust air.
Link to part http://www.manualslib.com/manual/337967/Whirlpool-Acp102ps.html?page=4#manual
Apr 15, 2014 | Whirlpool ACP102PS Portable Air...
THE UNIT BLOWS COOL AIR OUT THE FRONT BUT HOT AIR OUT THE BACK THE MODEL IS aP076E .i DO NOT HAVE A MANUAL BUT IT DOES NOT SEEM TO BE REAL HARD TO RUN THANKS
Yes, that is the way a typical air conditioner works. The portable types need to have the hot discharge air direct outside via flexible hose and an adjustable window bracket. The window closes on the bracket to create a seal, and the hose connects between the air conditioner discharge and the opening in the bracket. This is called "venting". Most portable air conditioners include (or offer as an accessory) a "vent kit" or "window kit".
Some portable air conditioners do not provide a way to vent - fortunately yours appears to have a kit for this purpose. You may wish to check out this page on venting. It has plenty of ideas and suggestions for venting. This site has some very good pictures to document making a vent - and is worth a look, too.
If this was helpful, please rate it "4 thumbs up" - thanks!
Aug 02, 2011 | Amana Heating & Cooling
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | NewAir AC-12000E Portable Air Conditioner
Hi On our portable DeLonghi air con, we have
Temp setting is very low. Raise it. And also service your unit frequently.
Dec 24, 2010 | DeLonghi PAC C100 Air Conditioner
Portable Air Conditioning unit no longer blows out cold air
Bit late I know, but for others having same issue, ensure that it doesn't need draining - use black tube at bottom left when viewed from behind to drain any excess water.
Jul 01, 2009 | Heating & Cooling
Missing window vent kit
parts@windchaserproducts.com contac them to get a replacement or go on their website to get their contact phone number. http://www.windchaserproducts.com
Jun 01, 2009 | Windchaser PACR90 Portable Air Conditioner
HELP l need instructions for Homebase LF320 air cooler
I have the same unit, also given to me, and there really isn't much to it. Remember, it's an 'air cooler, not an air conditioning unit. Works fine as a floor standing fan on L, M and H settings (lo, med and high) but, if you want the air to cool slightly, freeze the blue ice packs and then put them in the base of the unit and top up with cold water until the level indicator on the front says full (red ball hits red arrow, like in a kettle). Then, turn on as normal and run the 'Cool' function along with your desired fan setting (L, M or H). I tend to add a few extra ice packs. The 'Cool' setting drags a fiber membrane into the water and over the intake surface, thus cooling the air slightly. Nothing like real air con but better than nothing on a day like today. 'Swing' throws the air around a little and 'Mode' gives you bursts of air, and that's about it to be honest...
Apr 07, 2009 | House Brand Dryers
Washing Machines Logo
15 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
