Question about Newtoy Words With Friends Free
How do I delete addresses from my address book?
I need to know how to delete addresses that I do not need anymore on my Magellan RoadMate 1440
Here is a video that explains hoe to add, edit, AND DELETE address book entries in a Magellan Roadmate. The delete process is in the last minute or so if you don't want to view the entire process.
How do add edit and delete address book entries Video Demonstration
Oct 27, 2016 | Magellan GPS
Tip
Deleted Email Address Completely on Blackberry
to totally delete an email address on you blackberry you need to go to;
  1. setup email > log in > delete the email address then
  2. options > advanced options > service book > then delete anything that has the email address
on Sep 17, 2010 | Cell Phones
Deleting old email addresses on a Mac
There are two places to do that:
1. in the system address book (found in Applications/Contacts
2. in the address book of your email program. I use Thunderbird and Thunderbird has its own address book
Sep 18, 2014 | Apple Mac OS X 10.4 Tiger for Mac
Youtube
To remove ID's from your friends listright click username > delete gone, just like that... but by default, their entry still remains in your Yahoo! Address Book, unless during the Delete Contact confirmation screen you also select the option Delete from Address Book, too if you overlook this option and still wish to remove them from your address book, you can still do so (at any time) via your browser at Yahoo! Address Book
Jul 03, 2014 | Computers & Internet
How do I delete a contact from yahoo mail contacts list .
To delete a contact from your address book:
  1. In the Address Book, select a contact, then select Delete from the Contacts menu or select Delete from the right-click menu.
  2. In the Delete From Address Book window, confirm the deletion by clicking the Yes button.
    To delete one or more contacts from your Messenger List:
  1. In your Messenger List, select one or more contact names (hold down the Ctrl key while selecting multiple names), then select Delete from the Contacts menu or select Delete from the right-click menu.
    The Delete Contact window opens.
  2. Confirm the deletion by clicking the Yes button.
    Tip: Check Delete From Address Book, too to remove this contact from your Yahoo! Contacts
Oct 08, 2011 | Yahoo Mail
How to delete an email address (destination) from Ricoh C5000?
Hi, the email addresses are stored in the copier's address book. To delete one, press the User Tools button, then go into System Settings and go to the Administrator Tools tab. Choose Address Book Management, and a list of all the users will be shown. Choose the user whose email address you want to erase and press Delete. That address will be removed from the address book.
Jan 03, 2011 | Ricoh Aficio GX5050 GelSprinter InkJet
Want too delate a name from yahoo address book/error code 40402
This is a yahoo server error code
It can happen if you try and try and amend contacts from your friends list before your address book
Go to yahoo mail page > contacts > address book >check box next to contact to be deleted > delete
Open Messenger.
Right click on contacts avatar > delete
May 03, 2010 | Microsoft Windows 98 for PC
How can I delete an old email address from the drop down menu? When I send from Yahoo mail my old email address is used not my new one!
From the yahoo Email Screen
Select Options - Mail Options - Contacts - Address Book Home - this will display a list of all the contactys in your address book. You can then select each of the entries to delete then select the delete option in the inner window pane.
Nov 12, 2009 | Yahoo Mail
RECEING WAB HOT OPENING
Wab = Windows Address book.
it is possible that your address book has got corrupted,
you can delete your .wab address book or in outlook create a new address book to use (should be under tools)
Apr 26, 2009 | HP Pavilion dv6000z Notebook
Delete name from recipient list for scanned documents
There are 2 ways of doing this (1) it can be done from the panel, and (2) you can do it remotely via your web browsing application (internet explorer or the like). The remote option is the easiest way.
Open your Internet Explorer (or alternative web browser) and in the address bar (where you would normally type in the address of the web site you wopuld like to visit) enter the I.P address of the machine. The I.P. address can be found on the machine by pressing the * (star) button with the head shape around it, then on the touch panel press "system settings" > "network Settings" > "TCP/IP settings" > I.P. Address.
Once the page has loaded you may be asked to select if you wish to log in as a user or as administrator. in this case, choose administrator. On the left of the page that opens click address book, and on the right hand side click the address book where the addresses are stored (you'll see there is a section that tells you how many addresses are stored in each... most likely your addresses will be stored in "address book 1" or in "One Touch Addresses"
Once you click on this the list of stored addresses will appear. to the left of each address is a small blue square. Simply click on this square and then at the top of the page on the red X. Follow the same procedure to delete any other address. when you're done, simply close the web browser.
If you choose to do it from the machines panel follow the procedure below.
1) Press the star button with the head around it
2) select "address book settings" on the panel
3) If your address are stored in one of the general address books select "Register address"
4) select the address that you wish to delete and press the "erase" button at the bottom of the screen
5) press on "yes" in the screen that appears
6) follow steps 4 and 5 to delete any other addresses
normally the erase button is grey. if it does not activate when you touch on an address, then that means the address is stored in the one touch address book. to erase these addresses follow the same procedure as above, but in step 3 select "one touch buttons"
If your machine has been configured with a "System Admin Password" and you do not know this password you may not be able to delete any address. In this case you will either need to try and find out who configured this password and get it from them, or you'll have to get a Canon Technician out to reset the passwords on the Service mode. But the good news is in most cases even if your machine has this password configured you should still be able to delete addresses
Have fun
May 09, 2008 | Canon imageRUNNER C3220 Color Copier
Newtoy Words With Friends Free Logo
23 people viewed this question
Top Newtoy Apps Experts
Hampi Hemp
Hampi Hemp
Tom M
Tom M
Are you a Newtoy App Expert? Answer questions, earn points and help others
