Question about Saws
What size bolts hold on the pivoting shoe ?Mastercraft maximum reciprocating saw model54-8170-8
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: reciprocating saw problem
OK just looked at the Searspartsdirect.com website and there are 2 parts that I think it could possibly be. One is the SHOE part # 399725-00 list 4.86 in stock and or guard 157325-00 list 4.59 also in stock. I would suggest that you go to this site and confirm which one you need, but the shoe is the piece that does ride against the work surface. Good Luck and let me know if I can help further
Posted on Jan 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: reciprocating saw only works at certain angles
It sounds like the cord has a broken wire in it or there is a loose wire at the switch. Unplug tool and if you are comfortable in removing the handle halves look at the switch wiring and I pull gently on the wires from the cord to see if a can pull one out. Let me know if you still need assistance and I will go into more detail.
Posted on May 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
jeff_drakesr
  • 155 Answers
SOURCE: I need a Makita Assembly manual for 4390D
Here you go click on the links below for the pdf file. I hope this helps, please rate if the answer provided has helped. Good Luck and have a Great Weekend.
Parts Breakdown
Product Manual
Posted on Apr 04, 2010
Testimonial: "I received duplicate information from you and one other both were very helpfull in resolving my assembly problem "
HOW DO YOU put new boot back on ryobi reciprocating saw?
No. You spin it onto the tool clockwise. When you get far enough on, the lever will slip right into the slot.
I like to take my shoe off, and use my foot to hold the hand grip while sitting down. This allows me to use both hands to twist the rubber grip off/on.
Jun 24, 2015 | Ryobi Rj165v Reciprocating Saws
How do I separate the field case from the reciprocating part of a Craftsman reciprocating saw model 900271261
You have to remove the big rubber boot on the end of the saw to get at the screws that hold the gear case on the field case. First remove the shoe off the nose then, you may need help here, pull the boot off the gear case. Some come off easy, some have to be helped off with a long screwdriver prying up at sticking points until the boot comes off. After that, remove the four screws holding the two cases together.
Aug 14, 2012 | Craftsman Saws
How do u take off the top of a dc385 cordless sawsal to unscrew the two top screws .. is there any video?
there is no video, but you can download a breakdown for this tool at "dewaltservicenet.com" to see what I am going to explain. first remove the battery, and the pivot shoe. Next pull the gearcase insulator off to expose the gearcase housing and then you will have access to all the screws that have to be removed in order to unscrew the top. The gearcase insulator is sometimes "tight" to remove so you might have to pull hard but it will come off. Let me know if you need more assistance.
Mar 15, 2011 | Dewalt 18v Dc385 Reciprocating Battery...
How can remove gearcase insulator?
first reove the pivot shoe and then get a GOOD PAIR of pliers and on the front end grip the insulator and "pull" you will have to lift the insulator over the slide control for the orbital action but that is the only way
Jan 24, 2011 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Mastercraft Maximum Compound Mitre Saw
built by canadain tire company their customer service number is 1-866-746-7287 they should be able to get u replacement part and or advise who in ur area can
Jan 25, 2010 | Saws
How do I disassemble a craftsman 10 amp reciprocating saw?
To remove the front half of the saw:
1. Remove the two screws that hold the guide shoe
2. Pull and wiggle the guide shoe straight forward and out.
3. Remove the metal support from the front of the rubber boot by prying it out of the groove.
4. Using a pick or a very small screwdriver, pry the retaining pin from the blade release handle and remove from the front. It removes without much friction.
5. Remove the blade release handle through the side of the saw by wiggling and releasing the return spring.
6. Remove the rubber boot off the front of the saw by gently prying near the center of the saw and firmly pulling.
7. Remove the six screws to remove the black plastic dust cover.
8. Remove the remaining two screws and lift the grease guard to access the reciprocating mechanism, being careful not to drop the needle-bearings. This area can be packed with grease.
The handle part of the saw is self explanatory.
Dec 26, 2009 | Saws
I need spare parts for my saw and if possible a diagram parts requierd are carbon brushes x2 and brush holder assembly . Kind Regards Stephen.
mastercraft 10" compound saw model #55-6802-6-- need spare parts - How do i get them.
Need center bolt for blade
Oct 05, 2009 | Saws
Reciprocating saw problem
Jan 17, 2009 | Craftsman 8.0 amp Reciprocating Saw
Saws Logo
42 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
