SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
SOURCE: how to finalize a recorded dvd disc?
on the remote is there quick navi button (this will take u to the finalizing screen)
SOURCE: Unlock Toshiba DVD Video Recorder
In this recorder the region is hard coded in the firmware and cannot be changed thru customer commands. Unfortunately there is no region free firmware so if you would be able to obtain one all you would manage is to change the present region to another one.
SOURCE: My Toshiba DR430KU dvd recorder
Hello
Secure the audio/video connection cables that attach the source device you are trying to record from. Try this step if you do not see a picture when trying to record from a source device onto the Device. After unplugging the cable and checking for any damage, plug the cables back and attempt to record the content to see if this resolved the problem.
Secure the power cable that attaches the device to an electrical source if the unit will not power on or if it intermittently loses power. If you think a malfunctioning surge protector may be at fault, you can 'bypass' the surge protector by plugging the device into an electrical outlet. Replace any surge protectors that appear to be malfunctioning and have an electrician examine any outlets that appear to be "dead."
Insert the disc that you would like to record
Press the "Edit Menu" button on the remote control while playing the disc or while playback is stopped.
Use the up and down arrows to select "DVD-Video Finalizing" in the on-screen menu, then press "Enter."
Under "Menu Create" select "None," then under "After play final title" select "Stop." Select "Next" to move to the next screen.
Select "Writing" in the lower right of the screen.
Select "Yes" or "No" to tell the machine if you want it to power down when finalizing is complete. Finalizing will then begin and a progress bar will appear.
Contact your electronics dealer or the Toshiba service department if the disc still does not finalize.
