Question about NEC Lands Phones
Turn off speakerphone nec aspire - NEC Lands Phones
Nec 12txd phone not ringing and led indicator not working.
the only other setting that could turn the led off is if you enable blocking mode and you check disable led indicator (found by long pressing blocking mode in the pull down window). do you have any apps that could control the led lights like light manager? if so, try uninstalling it or checking its settings. if you dont have an apps like that, have you tried installing one to see if it works?
Feb 24, 2014 | NEC Aspire 22 Button Ip1na-12txh 0890043...
The speaker phone will not work
If you have the speakerphone option enabled in system programming, you may just have the mic turned off. Try pressing Feature then 1 while the phone is idle. The mic light should light up if it wasn't already lit.
Apr 13, 2011 | NEC DTH-8D-1 Corded Phone
Speakerphone
Yes turn your mic light on. Feature 1 usually.
Nov 06, 2008 | NEC Electra Elite 32D-1 Corded Phone
NEC Telephone speakerphone. You can hear the caller, but they can't hear you.
Chance's are it's a bad hand set, Swap with another to see if problem follows it. if it dose, replace it.
Richard
Oct 01, 2008 | NEC DTU 8D-2 Corded Phone
NEC DTERM 80 Call to speakerphone
While the station is ringing - Press "1"
The feature must be enable in programming to be active.
Mar 06, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Speakerphone
Sounds like the mic is turned off. Try "FEATURE - 1". You may have to do it twice.
Feb 05, 2008 | NEC DTU 16-1 Corded Phone
NEC Aspire Phone
Press the CALL 1 key and dial 821. That will change it back.
Oct 01, 2007 | NEC Lands Phones
Speakerphone does not work
Try pressing the Feature button and dialing the digit 1. This will turn the microphone on and the MIC lite should turn red. Don't lift the handset or press Speaker, just press Feature 1. This will also turn the MIC off if you want it disabled again.
Nov 06, 2006 | NEC DTU 8-1 Corded Phone
Lands Phones Logo
48 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
