Question about Samsung HL67A750 67 in. TV
Samsung DLP TV MODEL HL67A1FXZA parts breakdown
Need FAN NUMBER 3
  • 4234 Answers
SOURCE: Samsung 50" DLP TV
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
Keep us posted.
Dan
Posted on Jun 27, 2008
ginko
  • 19396 Answers
SOURCE: samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Posted on Jul 26, 2008
Slinteriors
  • 8617 Answers
SOURCE: Obtain repair manual for Samsung DLP projection TV's.
You can get the service manual by download link within minutes from the following link. Just scroll down the page and you will see your model listed.
http://www.tvrepairworld.com/service_manuals
Posted on Dec 24, 2009
Testimonial: "Your solution was very timely and helpful. Thanks"
eddiepeezy
  • 130 Answers
SOURCE: My Samsung 50'' DLP msg "Check Fan No. 3"
You can attempt to remove the back cover, but there is a very delicate mirror in the back. I'd just move it away from the wall, used compressed air to clean out the fans, and put everything back together. Just make sure you don't damage the color wheel or light engine.
Posted on Feb 04, 2010
Testimonial: "I will do this, thanks. Do you know where I could order a replacement fan no. 3 for this model if neccesart? "
Angel Petter
  • 114 Answers
SOURCE: White spots on Samsung DLP
Hello the problem here is absolutely the DMD Board this is a commune problem with the Samsung DLP
are your spots like this picture?
try this link...
http://www.discount-merchant.com/
Posted on Feb 06, 2010
How to replace fan 3 samsung 61 in led dlp
First thing would be to remove cover and look at fans, dirt or dust on one will lock it up.
Google the model number with Parts and a good idea if one or more are identical is replace or even swap them.
The lamp fan and main fan should be easy to see with back removed and are plugged in so if an exact replacement is obtained a few screws and plug and back in business.
Aug 26, 2012 | Samsung HL61A750A 61" HDTV
Samsung DLP TV, model HL67A750A1F fan #3 message then turns itself off
Please check the all fan if working properly if all works fine you have defective board inside behind fan # 3 you need to replace it..
Dec 13, 2011 | Samsung DLP HL-P5663W 56" TV
TV turns on but lamp never comes on. Seems to try 3 times then all 3 led's on front start flashing. I tried to replace the lamp but problem remains.
If the Lamp has been replaced then problem will be either Lamp Fan or Ballast board .
Ballast board connects to Lamp and it is what powers Lamp on.
Check out Encompass Parts Distribution type in your Model number for a List of Parts/Prices and Part Numbers.
Samsung Parts 1-800-627-4368
Jun 23, 2011 | Samsung DLP HL-P5663W 56" TV
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
Cooling fan motor is making loud humming noise
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
May 18, 2009 | Samsung HL-S5087W DLP TV
DMD Board failure on Samsung DLP
Try here:
http://www.partstore.com/GetModel.aspx?MfgName=Samsung&BrandName=Samsung&ModelNumber=HLN5065WX&PartCategoryName=&Keywords=board&Page=1&SortBy=price&SortDirection=asc#PartsearchSKUList
Feb 02, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung dlp hl-r5667w
This Tv make a lot problems with the color wheel and fan thermostat, lamp cool. Need be check the color wheel first. I am suggested dont have nothing on the back cover ( make hot or not ventilation). More information parts at tritronicsinc.com Thank you
Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HL67A750 67 in. TV Logo
Jerry Greenberg
Jerry Greenberg
