Question about Saeco Royal Exclusive 30153 Espresso Machine
Coffee is just water
When trying to make coffee i only get water
  • 67 Answers
You have to put ground coffee beans in, too
Posted on Jun 23, 2009
Why is my coffee weak?
If it is a drip maker, only gravity drives the hot water thru the coffee grinds. If the coffee is ground too fine, it immediately packs up and doesn't let water flow thru it and the water flows around the coffee instead of thru it.
Try using a coarser grind, and if not you can use a lot smaller amount of coffee and water. A smaller amount of coffee is easier to diffuse thru than a large amount.
Another thing is to slow down the water speed entering the coffee basket. I found the best way to do that is to use water just above freezing and place that extra cold water in the reservoir. The cold water takes extra time to be heated up by the coffee maker so less water is released over the coffee grinds per minute.
If your coffee maker overflows a lot, that is a good indicator that the grind is too fine and/or your coffee filters are too flimsy and are plugging up the channels in your coffee basket and the coffee can't enter the flask, so it overflows.
But the easiest way to check out your coffee maker is to use extra cold water and just run half batches (5 cup) of coffee instead of 10 cup
Feb 25, 2015 | Coffee Makers & Espresso Machines
Tip
No hot water from coffee tap, Sometimes only some drops no pressure
One possible problem is to try to clean the group shower which it can be ansrew by one center screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Both the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
One other posibble problem is the vibrating water pump. It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
on Mar 28, 2010 | Coffee Makers & Espresso Machines
Coffee tastes bad in old and new coffee makers
Have you tried first just running distilled water through it, then again with spring water and then test with enough coffee for 1 cup to see how the cofee taste then. Also you may want to use distilled or spring water when making that one cup of cofee to test.
Dec 17, 2013 | Mr. Coffee Coffee Makers & Espresso...
When trying to make coffee, very little water passes through the kcup, most of the water "recycles back into the tank
when trying to make coffee, very little water passes through the kcup, most of the water "recycles back into the tank
Jan 02, 2011 | Keurig B60 Coffee Maker
Insufficient pressure to force water through coffee
Propably the vibrating water pump is the problem.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water. Then try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
Good luck
Jun 04, 2010 | Krups Cappuccino/Espresso Maker -...
Water goes into bottom tray
Good luck
May 16, 2010 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water (coffee) does not make it out through the coffee handle spout. Hot water seems to be coming out of machine into the ground beans but there does not appear to be enough pressure to get it through the...
Good luck
Mar 25, 2010 | Breville Die Cast 800ESXL Espresso Machine
Flashing water light - will drain water but will not make coffee
Something is wrong on the coffee cycle side of the machine. Check the brew unit screens and and try doing a preground cycle with out inserting coffee. IF water comes out, I would looking into your grinder a little bit and try increasing the grinder size.
Espresso parts and service
www.cerinicoffee.com
Dec 08, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Exclusive 30153 Espresso Machine Logo
82 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
