Question about Maytag M7DH45B2A Dehumidifier
Full light dose not go off
Pulled out water tank, and the light will not go out so it wount go on
Does not shut off when tank full, water leaks all over the floor if I don't watch it constantly
Sounds like the float valve inside tank may be stuck in closed position. Calcium buildup is very common. Good luck Juliana. Unplug and empty tank of any water and look for the float valve it should be near top of tank. Use a small bucket and mix vinegar and water and brush. Scrub that valve. Clean it up
Jul 13, 2016 | Windchaser Dehumidifiers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Full light stays on always
Don't know your model specifically, but most dehumidifiers have a float that shuts the system down when the tank is full. Maybe the float is not going up and down like it should. With the power off and the tank out, see if the float is descending like it should when the tank is out. Popping it up and down a few times might solve the problem.
Apr 13, 2014 | Comfort-Aire Dehumidifiers
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
Unit wont turn on,,, water full light flashing
is it full of water if not maney times it senses a full tank by a scale on the bottom of the water pan try to pull up on the plate where the bucket sits make shure its not stuck let me know pls jason
Apr 08, 2010 | Maytag M7DH45B2A Dehumidifier
A red light saying full is on. what does that mean? this is a Westpointe de-humidifiier
it means you tank is full of water and needs to be emptied
you can slide it out, dump the water ( i use it for my garden)
then replace the tank
the light should go out
Oct 09, 2009 | Midea MDC-45AE Dehumidifier
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Sep 03, 2009 | DeLonghi Dehumidifiers
Newair ADS-300 Dehumidifier
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Danby DDR451 water tank
I had this to. Check to see if there is any packing tape just above the tank. The tape on mine was not tapping the tank shut; it had been there for a year (not interfering with anything), but i pulled it all out anyways, and the tank let go!
that's what worked for me... hope this helps
Mar 08, 2008 | Danby DDR451 Dehumidifier
Danby water tank
this part is the indicator to activate the interlock that stop your deshumidifier when water tank is full. It activate a switch on the top right of the placeholder of the tank. when the switch is relaesed it tells you either thank is not there or full and light a red signal. the center of the wheel should be back the pivot. if the pivot is broken, i don't suggest you to forced the switch activated unless you use the direct drain, or you might have water spilled over a full bucket! Martin!
Aug 04, 2006 | Danby DDR451 Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
26 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
