Question about iPhone Apps
My kobo touch will not charge - iPhone Apps
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
My Kobo glo, after charging it, went to very small print, and the words don't fit on the page. How can I reset it?
On my kobo, I have to touch the middle of the screen to get the toolbar to pop up at the bott of the screen. You should the find the usual icon.
Oct 22, 2014 | KOBO, INC Kobo Glo
I have to keep me kobo plugged in while I read. Can I fix this?
Unfortunately, Kobos weren't designed to replace the batteries. Short of buying a new eReader, reading with it plugged in is the only way around bad batteries.
Oct 16, 2014 | Kobo 6" eReader Touch Edition
Why is my kobo In Demo mode so I can't buy books!
Type demo off or demomodeoff in the search bar
Aug 30, 2014 | Kobo 6" eReader Touch Edition
My kobo wont turn charge and turn on
Broken psu connector or moethboard junk it its not cost effective to repair.
Aug 20, 2014 | Kobo Arc
Kobo ereader problems
Unfortunately, the batteries on Kobo were not designed to be replaced. If the batteries will no longer accept a charge, it is time for a new e-reader.
Aug 14, 2014 | Kobo 6" eReader Touch Edition
Kobo help
Clean water, I hope, otherwise chances are much worse. DON'T turn it on. Pat it dry as much as possible, then completely bury it in a sealed jar of uncooked rice for maybe 3 days. After that, try turning it on. If nothing, try charging for several hours. If still nothing, sorry!
Aug 11, 2014 | Kobo 6" eReader Touch Edition
My touch screen kobo reader has stopped working
Make sure the Kobo is fully charged and switched off. Hold down the 'HOME' key while turning the Kobo on. When you see the power light release the 'HOME' key. The lights will flash. Follow the onscreen prompts.
Jan 06, 2012 | Kobo eBooks by Kobo
iPhone Apps Logo
65 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
