Apple Mac OS X 10.4 Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"First Aid" in Mac Disk Utility is Blank!
I opened up my Disk Utility in Mac OS 10.4, and the First Aid tab comes up blank when I select a volume. The same with Erase. When I click off, then back on to the First Aid tab, the program essentially freezes. Anybody else have this problem? It's a weird one. Thanks.
Anonymous
Level 2:
Scholar:
  • Expert 50 Answers
  • Posted on Jul 19, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
50
Questions
0
Helped
20485
Points
102
Yes, that is very weird.
First thing I would try is tossing the preferences. Find the file "com.apple.DiskUtility.plist" in your home directory "Library/Preferences" folder.
If that does not work: Do you have more than one volume on your computer? Does this happen with every volume?
You could also try to boot from the OS CD (or the restore CD that came with your computer). Disk Utility is available under the "installer" menu. Don't run the installer, just look for the "disk utility". If that also does not work, then there may be something wrong with logic board.
Time machine on MAC 10.5.8 will not open; error message -43
error -43 fnfErr: File not found
Could be many things, we should start with this...
"Try Disk Utility
1. Insert the Mac OS X Install disc, then restart the computer while holding the C key.
2. When your computer finishes starting up from the disc, choose Disk Utility from the Installer menu at top of the screen. (In Mac OS X 10.4 or later, you must select your language first.)
*Important: Do not click Continue in the first screen of the Installer. If you do, you must restart from the disc again to access Disk Utility.*
3. Click the First Aid tab.
4. Select your Mac OS X volume.
5. Click Repair Disk, (not Repair Permissions). Disk Utility checks and repairs the disk."
http://docs.info.apple.com/article.html?artnum=106214
Then Repair Disk on the external drive.
Then try a Safe Boot, (holding Shift key down at bootup), run Disk Utility in Applications>Utilities, then highlight your drive, click on Repair Permissions, reboot when it completes.
(Safe boot may stay on the gray radian for a long time, let it go, it's trying to repair the Hard Drive.)
If perchance you can't find your install Disc, at least try it from the Safe Boot part onward.
If TM display doesn't even show up, see this...
http://pondini.org/TM/E4.html
And also i share a link to another error issues.
http://www.macworld.co.uk/feature/mac-software/common-mac-error-messages-3502033/
Thanks,
Mac Support
tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 • Computers & Internet
tip
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
on Feb 11, 2010 • Computers & Internet
I've been scanning to my computer w/ my cannon mp240 and suddenly cannot. It still scans and prints and prints from my computer, but the scanning to computer has stopped. I have a MAC and it's worked...
The printer drivers for the MP240 are intergrated in the Mac OS X.
If software for your printer was included with the Mac OS X installation, check the printer manufacturer's website for updated versions. Install a printer driver available from the manufacturer's website only if it is a newer version than the one included with Mac OS X.
Repair disk permissions
Tip
: For more information about Repair Disk Permissions and Mac OS X v10.2, v10.3 or later, see "About Disk Utility's Repair Disk Permissions feature".
  • Mac OS X v10.3 or later: Open Disk Utility (/Applications/Utilities/). Select your Mac OS X startup volume in the column to the left of the Disk Utility window, then click the Repair Disk Permissions button.
  • Mac OS X v10.2 through 10.2.8: Open Disk Utility (/Applications/Utilities/). Select your Mac OS X startup volume in the column to the left of the Disk Utility window, then click the First Aid tab. Click the Repair Disk Permissions button.
  • Mac OS X v10.1.5: Update to Mac OS X 10.1.5 if you have not already, then use the Repair Privileges Utility. See "Mac OS X: About the Repair Privileges Utility 1.1".
Reset printing system (Mac OS X v10.4 and later)
If other steps haven't helped, you can reset the printing system. Important: This should only be used as a "last resort" when troubleshooting a printing issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My laptop does not recognize my iomega hard drive
You need to format your drive to work with your Mac. The drive is shipped formatted as NTFS (Windows).
I'm going to assume that you are using Mac OS X 10.5 or later.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive.
********Make sure you click on the high level icon, not the second level volume icon.********
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
tip
Mac Repair Disk
Mac OS Repair
To run Disk Utility on apple macbook OS X 10.4.x, you must start the computer using an Apple Software Restore disc.
Insert the disc into the computer, restart.
After you hear the startup sound, press and hold the "C" key. Hold the key until you see the gray Apple logo.
Your computer will take longer to startup, be patient, this is completely normal. After the CD or DVD is loaded it will automatically start the OS installer, do not reinstall your OS system!
If you are requested to choose a language, just click the right arrow button (Next).
To open the Disk Utility Click on Utilities > Disk Utility.
Now the Disk Utility window should be open. Choose from the left side of the window the hard drive you wish to repair (in this case Macintosh HD).
Make sure that the First Aid tab is selected.
Click Repair Disk button (bottom right).
The tool will check your hard drive, if it encounters any problems it will list them in the middle of the window, otherwise you'll receive this message - "The volume Macintosh HD appears to be OK".
Once the scan is over if it found problems, click again on Repair Disk, this will try to repair the problems, if not successful you need a more advanced utility tool.
on Aug 17, 2008 • Apple Mac OS X 10.4
My mac is not recognizing my disk from my hard drive
Open Disk Utility (as I'm sure you already have) and select the main partition of the problematic disk on the left side, which should be titled disk1s10. In the First Aid tab, click the "Repair Disk" button on the bottom right hand corner of the window. *Note: If this is the current boot disk, you will have to boot off of the Mac OSX Install Disk by inserting it and holding the "C" key while it is turning on. Select your language and choose Utilities --> Disk Utility from the menu on the top of the screen, then following the above instructions.
2answers
When i turn it on it's saying there's no such file directory. It's a dual core processor I tried to switch it from Os9 to Os10 and now it's got a black screen with this on it
Try starting from CD and check hard drive. Sounds like you installed something that may have corrupted something on your hard drive.
1helpful
4answers
Mac Disk Utility Problem
1.Insert the Mac OS X Install CD or DVD.
2.Restart Mac, immediately after the bong, hold down the C key until the Apple logo appears.
3.When the Installer reaches the INTRODUCTION phase, click on Utilities at the top of the screen, and drop down to Disk Utility.
4.Click the First Aid tab.
5.Highlight the boot hard drive volume or partition.
6.Click Repair Disk.
7.Repeat steps 5 and 6 until the scan comes up all clean and good (and run it one more time).
8.Quit Disk Utility and the OS Installer and reboot.
9.Firewire Target Disk Mode is another option we should know about.
Cheers.
Imac notebook
your hard drive is not being seen when the computer boots. If you have the Install DVD that came with it, follow these steps:
1. Start up from the MacBook Pro Mac OS X Install Disc 1 DVD that came with the computer (hold down the “C” key during restart).
2. When the Installer opens, from the Installer menu under Utilities, select Disk Utility.
3. When the Disk Utility opens, on the left hand side, all disk and volumes are listed. If you don’t see the internal hard drive, the system is not recognizing it. Skip to the next step. Otherwise, select the internal hard drive icon and follow the instructions under the First Aid tab to verify
the hard disk, and repair if needed. Restart the computer.
if it still doesn't see it, your hard drive is most likely dead and needs to be replaced. Go to an apple store or call AppleCare if it is still under warranty. If not, you need to get a 2.5" SATA hard drive to replace it, and then reinstall the OS on the new hard drive. If you have a friend with a mac, you can try booting your computer to target firewire mode (holding T when you press the power button until a biohazard-like symbol appears) and connecting it to an already booted mac (your computer will appear as a hard drive, and you can try to copy whatever stuff is possible onto the other computer to back it up)
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
