Question about Kenmore 98702 Stacked Washer/Dryer
Fills and Drain...
In the regular cycle, the washer fills and drains mulitple time before washing. then fills and drains mulitple times, then again during the rinse cycel it fills and drains mulitple times... Please help
  • 5,911 Answers
Check your washer drain line for a possible siphoning condition. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Read through the link I provided. Your problem may be a simple matter of drain hose placement. If this does not solve your problem, please post back and let me know. I hope this helps you.
Posted on Jun 23, 2009
Hi, I am trying to help daughter-in-law get their
Hello annp, thank you for your post! Based on the symptoms you are describing, it does sounds like a siphoning issue. Generally speaking, the drain hose should come up above the washer tub and please make sure the drain hose is not too deep in to the house drain pipe. The drain hose should only be submerged 4-8 inches into the house drain pipe. If correct, otherwise the unit might be experiencing a communication with the control board and water fill valve. At this point, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - please do not hesitate to reconnect.
Jul 31, 2013 | Frigidaire FGX831C Top Load Stacked Washer...
Mine fills up and drains at the same time also doesnt agitate during wash cycle
This happens on new installations usually. The drain hose must be higher than the highest fill height of the washer. If the drain hose is to low it will create a siphon effect and drain the machine. Next is the drain hose is to tight in the standpipe. The standpipe is your homes plumbing. If the drain hose does not have an air gap around it, it can cause a siphon effect and start draining your machine as it fills. If none of these are the problem and your drain pump is running at the same time it is filling you will need to replace the control. http://appliancehelponline.com/washerdrainsfills.html
Sep 21, 2010 | GE WBSR3140DW Top Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer fills and drains at the same time. doesn't change cycles
check the washer drain hose, it is probably sipening the water back out, try pulling it out of the drain a few inches
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
Washer continuously filling/emptying
Your drain hose from the washer is in your household drain line too far, should not be any further in the drain line than 7 inches
Mar 23, 2009 | Washing Machines
Top loaing washer fills then mostly empties repeatedly
Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
If it fills and stops, then starts agitation. Repair the drain hose.
Mar 23, 2009 | Kenmore Washing Machines
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
102 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
