Question about Sharp LC-60LE600U 60" LCD LED TV 1080P
My sharp auos lc60le600u won't turn on light comes on clear
Replacing led strip(s) in a Sharp Aquos LC60LE600U TV
It is somewhat skilled work. You have to disassemble the display pane, to replace it. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Disassemble procedure to many popular devices are given with illustrations.
Jul 25, 2016 | Sharp Televison & Video
2009 engine light came on after a sharp turn
Hello, if you still have the engine light on you can take it to Advanced Auto or Auto Zone and they will scan the codes for free. They can clear them also. After they clear them if they come back then write them down and get them to me and I can let you know what may be causing your issue. Also, what is the year make and model? feel free to call once you get the codes if you like 561 615 0103 hope this helps. Regards, -Tim
Nov 24, 2014 | Cars & Trucks
Does not stay on power
Main board fault.
Shorted component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 06, 2014 | Sharp AQUOS LC60LE600U 60 Inch 1080p 120Hz...
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Need to set up tv
Download its user manual from here and check it.
Oct 21, 2012 | Sharp AQUOS LC60LE600U 60 Inch 1080p 120Hz...
I have a 3year old Sharp TV. It won't turn on like it should. I turn it on and the red light goes out and it stays out. Then it comes on again. I turn it on and the red light goes out. If I am luc
Power supply or something in the set not allowing supply to come up, not likely to be a do it yourself repair---consider having a tech or a shop look at the set.
Aug 31, 2012 | Sharp LC42SB45U 42 in. LCD TV
Light won't come on
please tell us what you see and hear when you turn it on.
which light are you referring to?
Jun 06, 2011 | Sharp Notevision PG-B10S Multimedia...
TIMER LIGHT BLINKING AND POWER IS NOT COMING ON CD-SW330
i have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing, i have done the bit it says about pressing the timer button then arrows and memory but that doesn't seem to work help?
Jan 09, 2011 | Sharp CD-SW330 Shelf System
When I turn the tv on, the green power light comes on and then immediately turns off, (light goes red). No image or anything comes up on the screen. Never had any problems before this. Checked all plugins....
Use the remote to switch problem,if it's not works,I am sure the power board problem
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Sharp LC-60LE600U 60" LCD LED TV 1080P Logo
115 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
