Question about Rheem Pool & Spa
Pool heater ignites, gets hot, but I get no hot water to pool
    Top Expert:
  • Rheem Master
  • 5,922 Answers
Check manual bypass
Posted on May 19, 2016
SOURCE: Pool heater burners won't ignite.
Also you need to inspect the igniter.
Posted on Apr 25, 2009
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
SOURCE: Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Posted on Sep 16, 2009
  • 366 Answers
SOURCE: triton minimax 400 pool heater won't ignite
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
Rheem pool heater
Gas on, door safety switch, fuse box breaker on? New install, older, or shut down while in service. Please give more details. Make trouble shooting easier and get you fixed up fast. Thank you.
Oct 06, 2013 | Pool & Spa
Getting ignition lockout code
1-water flow ? gas related , is propane or natural gas ?
Jun 09, 2013 | Legacy Jandy Lrz250en Swimming Pool Spa...
What would cause the return manifold get so hot it would melt? Water was running thru the manifold and was returning to the pool.
It sounds like the internal by-pass is stuck open, and is not forcing enough water through the heat exchange. The Hi-Limit switches should have shut off the heater before damage occurred, so you have more than one problem with this heater.
Sep 09, 2011 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Why would the hot surface igniter burn out in two months?
It is very frail if you bump the heater hard while it is hot or cold you can crack it. If you have any water leak inside the heater or a condensation problem that drips water on it while it is hot this will break it every time.
May 07, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
HEATER RUNS (HOT EXHAUST) WATER IS CURCULATING ( CAN FEEL AND HEAR) BUT WATER IS NOT WARM OR HOT ?
As hot water leavs the heater it mixes with cold water so what you feel at the pool side is barley warmer than the pool. This is ment to keep from scalding people in the pool or spa. 7-11 degrees is the max on the outlet.
Apr 24, 2010 | Hayward H Series Pool & Spa Heater 400k...
My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Apr 05, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pool heater cycles off and on
insert on hot water and see if open or close than on cold water and must reverse from hot. if nothing happen replace
May 29, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pool & Spa Logo
77 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
