Question about iPhone Apps
World at arms updates for windows 8 pc - iPhone Apps
Can I get tank simulator to work on windows 8
Walter,
Windows 8 has been having quite a few issues with compatibility with games that were made for earlier versions of windows. However, you can try right clicking on the icon for the game and then clicking "Troubleshoot Compatibility" Windows should be able to detect problems and fix it. If this doesn't work, there is an awesome, completely free tank simulator type of game out there called World of Tanks. It has amazing visuals and works perfectly with windows 8.
Here's a link if you are interested: http://worldoftanks.com/en/content/docs/update/
Jun 04, 2014 | Video Game Consoles & Games
The newest windows 8 updates
to update Windows 8:
From Desktop:
1. Tap & hold/ right click the Start button/ the bottom left corner
2. Tap/ select Control Panel
3. Search for 'Windows Update'
4. Tap/ click Check for updates
From Modern UI:
1. Swipe from right
2. Tap/ click Settings Charm
3. Choose Change PC settings
4. Tap/ click on Windows Update
Hope it helps!
-Janis
Jan 06, 2014 | Computers & Internet
I have had an Evesham PC desktop computer since 2002. I use Windows XP. Is there any possibility of downloading Windows 8? Annie
You might need to upgrade a few hardware items first also you might upgrade to vista then windows 8
Creating a new partition on your hard drive gives your future version of Windows 8 a place to live on your drive.
Knowing exactly how much space the OS requires helps you determine how large to make your partition.
Size requirements don't tell the entire story on their own, though.
Other factors like drive type and additional storage help ensure you get the best Windows 8 experience where your hard drive is concerned.
Size Requirements
Both Windows 7 and Windows 8 have the same system requirement regarding hard drive space, so if your hard drive can handle Windows 7, Windows 8 shouldn't be a problem.
For 32-bit versions of the operating system, you'll need at least 16 GB of available disk space. The 64-bit version requires 20 GB.
Your partition will have to be at least one of these sizes, depending on your OS version.
The PC Advisor website warns that these are literally the bare minimum requirements, and using these figures leaves you hardly any space to save files and install apps or programs.
Size Recommendations
You'll get more out of Windows 8 if the operating system has enough free space for you to install your favorite programs and apps.
PC World calls this extra space "breathing room," suggesting you give your Windows 8 partition at least 30 to 40 GB.
If you're dual-booting with another operating system or you're accustomed to keeping excess data on a separate partition, 30 to 40 gigabytes should be fine.
If you'd rather have all your songs, videos and PC games on the same partition as the operating system, consider giving it substantially more space.
Solid State Drive
Windows 8 works on traditional hard drives with spinning disks, but it's optimized to run on a solid state drive.
If you've got an SSD, consider putting your Windows 8 partition on that drive.
While any operating system benefits from the speed increase an SSD brings, ARS Technica specifically recommends this drive type for Windows 8, saying the operating system's "tablet-esque feel and search-heavy usage model will be much better served by solid-state storage."
Other Requirements
Hard drive space is a crucial system requirement, but others are just as important.
Ensuring your computer meets the other requirements before partitioning your drive for Windows 8 saves trouble in case your computer can't handle the OS.
You'll need at least a 1 GHz processor that support PAE, SSE2 and NX.
Your computer has to have at least 1 GB of RAM for 32-bit Windows 8, or 2 GB for 64-bit.
Your graphics card must be at least a DirectX 9-capable card with a WDDM driver. Also, while you're formatting your drive, format the Windows 8 partition in the NTFS format.
Storage Spaces
Storage Spaces is a useful Windows 8 feature when you're working with multiple drives and partitions.
The tool enables you to group drives into one larger storage space so you don't have to constantly switch partitions and explore different drives.
For example, if you create a storage space between two 32 GB flash drives, you'd be able to access it as if it were one larger 64 GB drive.
http://windows.microsoft.com/en-us/windows-8/system-requirements
Microsoft windows 8 system requirements
http://www.pcadvisor.co.uk/features/windows/3358892/windows-8-system-requirements/
PC World windows 8 system requirements
http://www.pcworld.com/article/2012847/how-to-master-storage-spaces-in-windows-8.html
PC World how to master storage space windows 8
http://windows.microsoft.com/en-US/windows/download-shop
Sep 11, 2013 | Evesham Computers & Internet
Driver for windows 8
To update Windows 8:
go to Control Panel (the desktop version or Modern UI version)
search for Windows Update
Click on Check for updates
Wait until it's done, if there are updates, install them, if no, just close it.
If you need drivers for your PC, then please say what is your PC model (who made it)?
Feb 24, 2013 | Computers & Internet
Is windows internet explorer 8 the same as microsoft internet explorer 8
Restoring Computer to earlier state is the best solution. Only update the Internet explorer by using online updates that is downloaded from Microsoft website. WebRepOverall ratingThis site has no rating(not enough votes)
Also try to update the drivers that control your PC.
If problem still occurs then use system utility tool PCFresher that will fix windows internal errors and will fix corrupt registry errors.
Dec 07, 2012 | Microsoft Windows XP Professional for PC
I cant play minecraft with out a code
You will have to make an account and buy it, Minecraft is not free. Buy it at Minecraft.net
Dec 31, 2011 | Kaltner.net Minecraft Mobile Admin
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
May 02, 2011 | Samsung B5722 Cell Phone
World of Warcraft laptop Issues
OK i play WoW and what your experiencing is the patching of the game and yes there are alot of patches. Keep on patching till your version is 3.1.2.9901
May 25, 2009 | ASUS G50VT-X6 PC Notebook
When I try to update my pc I keep getting an error saying that windows could not search for new updates. I also cannot update World of Warcraft I am getting an error halfway through. MSN Messenger also...
remove msn and world of war craft thne try windows update after the updates install reinstall msn and world of war carft this is more than likely a software conflicting error Looking forward to helping u Shaun
Nov 15, 2008 | Computers & Internet
iPhone Apps Logo
27 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
