I believe that this is a high-temperature error. so, you might need to move the printer to a cooler room or lower the temperature of the room that the printer is in.
If you have opened the iPad, to change the buttons, you must have made an error while reassembling it. I hope you did not glue it together, before you tested it, because it will be difficult (if not impossible) to open it again, without damaging the screen.
That is why (I'm a technician myself) I goto a repair store with Apple stuff. At least I get it back working, even if that tech makes an error.
Short answer. But Ithink you will find it usefull.
You should Google the Error code.
Just write: What is error -994 (FBAPIErrorDomain )
And then you'll find a site where Facebook helps you out.
It's much faster than me explaining it here:)
Good luck.
C.(DK).
You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/ * Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955 * Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above. * Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange * Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty. * Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept. * A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
