Question about VeriFone Computers & Internet
I have a problem on a Verifone m5, it just says check apn settings
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Tip
Wharfedale M5 DVD Region Free Fix
Wharfedale M5 DVD Player Region Free Fix
Would you like to unlock your Wharfedale M5 DVD Player to Region Free?
Follow these steps to unlock your Wharfedale M5 DVD Player:
  1. Press the Setup button on your remote control.
  2. Press the buttons 6, 2, 8, 3 and then 6 on your remote control.
  3. In the Regions Setting - Factory Menu page, set a specific region or choose All for Region Free playback.
  4. Press the Setup button on your remote control to exit the menu.
Your Wharfedale M5 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
Please my LG G4 dont have APN settings. How can I download it
Hi Yewande, Without knowing your internet provider I can't help you but you can find it by googling (APN settings for) + YOUR INTERNET PROVIDER.....CHEERS..
Apr 25, 2016 | LG G4
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
I can't make calls nor receive
Check to make sure phone is registering in network. Check a network is selected. Try the following.
APN & data settings To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From any Home screen, tap the Menu key.
  2. Tap Settings.
  3. Tap the Connections tab.
  4. Tap More networks.
  5. Tap Mobile networks.
  6. Tap Access Point Names.
  7. If available, tap the T-Mobile US APN (the bullet point fills with green). If not available, tap the Menu key, and then tap New APN.
    Note: To reset your APN settings, tap the Menu key and then tap Reset to default.
  8. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US LTE
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not set> OR Internet+MMS
    • APN protocol: IPv4/IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
  9. Tap the Menu key.
  10. Tap Save.
  11. Tap the desired APN profile you want to use. The bullet point fills with green next to the APN profile.
Manual network selection To manually select the wireless network the device connects to, follow these steps:
  2. Tap Settings.
  6. Tap Network operators.
  7. Tap Search now.
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
Switch 2G / 4G To change the band between 2G and 4G, follow these steps:
  2. Tap Settings.
  6. Tap Network mode.
  7. Tap one of the following desired band settings:
    • GSM / WCDMA (auto connect)
    • GSM only (2G only setting)
    • WCDMA only
Turn on / off Airplane mode Airplane mode turns off wireless connections. This allows you to use apps and menus, but not make calls or use the internet.
To turn on or turn off airplane mode, follow these steps:
  2. Tap Settings.
  5. To turn on, tap Airplane mode to select the check box. Tap OK.
  6. To turn off, tap Airplane mode to clear the check box. Tap OK.
Jul 06, 2014 | Cell Phones
Straighttalk settings for blu phone
try this one
had the problem going through forums trying to find the settings that work for my phone but to no success but I finally figured it out and I'm posting it on here just in case some one else has my same problem.
I had to create two separate APN's one for internet and one for MMS. Settings are as follows:
Internet:
Name: Straight Talk Internet
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: Not Set
MMS Proxy: Not Set
MMS Port: Not Set
MCC: 310
MNC: 410
Authentication Type: PAP or CHAP
APN Type: Internet
APN Protocol: IPv4
Bearer: Unspecified
MMS
Name: Straight Talk MMS
APN: att.mvno
Proxy: Not Set
Port: Not Set
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
MCC: 310
MNC: 410
APN Type: Internet+MMS
APN Protocol: IPv4
Bearer: Unspecified
Do not forget to create two separate APN's!!!!!
goodluck
Jun 23, 2014 | Blu Cell Phones
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
Mar 05, 2014 | Computers & Internet
Why i cant use my ovi suit from my nokia c3 theres always appearing on my screen saying contac your service provider.. my browser dont work. and i cant connect to internet but i can connect to wifi..
it seems you have wrong APN[access point number]
go to setting and check for your apn
call to the sim/service provider and ask for the apn setting
they will end it .after recieving apn set it as your default
thanx and regard
masood
Jan 23, 2014 | Nokia C3 Cell Phone
Mms settings for MIUI on HTC DD2 on Simple Mobile
Starting from any of the home screens- Press Menu- Tap "Settings"- Tap the "System" tab- Make sure that "Airplane mode" is unchecked- Tap "Mobile Network Settings"- Make sure that "Data enabled" and 'Always receive MMs" are checked- Tap "Access Point Names"If there other APNs are already stored- Select APN- Press Menu- Tap "Delete APN"- Repeat the above steps for all remaining APNsNow define the Simple Mobile APN- Press Menu- Select "New APN"- Enter the following information:-- Name: SIMPLE Mobile-- APN*: simple -- Proxy: <Not set>-- Port: <Not set>-- Username: <Not set>-- Password: <Not set>-- Server: <Not set>-- MMSC: http://smpl.mms.msg.eng.t-mobile.com/mms/wapenc-- MMS Proxy: <Not set>-- MMS Port: <Not set>-- MCC: 310-- MNC: 260-- Authentication Type: <Not set>-- APN type: <Not set>
*the APN field is case sensitive
- Press Menu- Tap "Save"
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Feb 10, 2012 | HTC HD2 Smartphone
I just want to ask,how to connect 3g in the phillippines via globe network?hope you can help me
You need to set the APN settings. Go to Settings->Wireless & Networks->Mobile Networks->Access Point Names, click the menu and "New APN" Please try the settings below:
Name: Globe Internet APN: http.globe.com.ph APN Type: default
Note: No need to set the other fields while creating the new APN.
Select the newly created APN. To connect to the internet, tap on "Mobile Network". It will then connect using the newly created APN.
This works on my HTC Wildfire. Hope this helps.
Mar 08, 2011 | HTC Desire Cell Phone
Computers & Internet Logo
52 people viewed this question
Top VeriFone Computers & Internet Experts
Martyn01202
Martyn01202
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
