Question about Moen & Villeta Two Handle Lavatory Faucet
One faucet handle has come off the base.
Have unscrewed the portion above the sink top, but cannot figure out how to raise the part that goes into the handle to make it work. Any help is welcome.
  • maberna Jun 24, 2009
    Thank you boss dad for the prompt reply. Will get puller and work with that.
  • 67 Answers
You have to make or buy a stem puller ----look for a retaining clip also
Posted on Jun 22, 2009
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
I cannot figure out how to get faucet apart to actually get the cartridge out. I removed the handle and I can see the cartridge inside but I can't get the housing off. Please advise. I have the...
Under the handle, there is a curved trim ring at the top that needs to be unscrewed from the base. This can be on tight due to hard water buildup. I cut two strips of rubber to wrap, one to wrap around the trim ring and the other to wrap base while using channel locks for the trim ring and a pipe wrench to keep the base from turning.
After that is off, you will see a large hex head retainer nut that holds the valve assembly in place. A spanner wrench will get that off fairly easy.
Reassembly is the reverse. Kohler specs the hex nut to be torqued at 9 ft-lbs or 1//4 turn past hand tight.
May 24, 2011 | Kohler Model 10430: Fort® Single-control...
Moen cathedral keeps coming loose and it base moves when you rotate the spout from sink to sink.
tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
May 04, 2011 | Moen Monticello Single-Handle Kitchen...
How do you get the handles off the Finial Traditional faucet so that I can tighten a compression nut?
Grasp the base of the handle under the lever by hnad and turn it counterclockwise. If the whole valve turns, you will need to hold the valve from underneith the sink with a wrench while you unscrew the handle base on top. It is difficult to see, even with the Finial owners manual from Kohler how the two join.
Oct 18, 2010 | Kohler Finial Traditional Widespread...
I was able to figure out how to get the handles apart, but can't figure out for the life of me how to get the center spout removed. Faucet is a Moen & Villeta Two Handle Lavatory Faucet
I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
Sep 15, 2010 | Moen & Villeta Two Handle Lavatory Faucet
I can't get the faucet to not move from side to side after it is tightened donw on the granite vanity top. The base is tight and does not move, but the faucet part still moves a little. How can this be...
The faucet should have come with a rubber gasket which goes between the faucet body and the granite top. Make sure it's properly aligned and has not slipped out of place. Be carefull when tightening the faucet to the granite, since granite is easily cracked.
Aug 10, 2010 | Moen 6102AZ Kingsley Single Handle...
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Trouble removing the faucet from a Delta Waterfall 174
I wouldn't worry about messing up the threads as it is an old unit that you wish to discard. Do what is necessary to hold the threads still with the vise-grips and loosen the nut until you reach the damaged threads. Then pull the faucet up from the top until the nut hits the bottom of the sink and cut the threaded nipple from the faucet with a hack-saw blade. Lay down cardboard to protect the finish of the sink and surrounding counter top.
I have had to do this many times and it usually saves you the headache of bloody knuckles.
Apr 26, 2009 | Delta Faucet Delta 174-SSWF Waterfall...
Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Nov 12, 2008 | Kohler Forte entertainment remote valve...
Moen & Villeta Two Handle Lavatory Faucet  Logo
224 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
