Question about Daewoo Computers & Internet
Dt42a1 daewoo black screen - Daewoo Computers & Internet
I HAVE A DAEWOO TV, INCHES F U SWITCH IT ON ONLY BLACK SCREEN WILL APPEAR WITH A COLORED LINE IN THE MIDDLE,HORIZONTALLY IN THE SCREEN....
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 09, 2016 | Daewoo Televison & Video
Monitor keep going to black screen while viewing.
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
Apr 22, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Daewoo 42" Plasma dp-42sm lines in screen
The problem is you have a cold solder joint on a component on the flex harness. My son will show you have to fix it on YOUTUBE. Check it out!
http://www.youtube.com/watch?v=EFpXYnGZCU0
Jan 14, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo lcd dlt 20w2
Hi this is warjis ahmed,
I can solve your problem of DLT-20W2
My email> warjisahmed@hotmail.com
Oct 29, 2008 | Daewoo DSL-17DW3 17.1 in. HD-Ready LCD...
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Vertical bar on Daewoo Plasma screen
The main problem of this model is VPB (video process board) and the reason is they build in it SMD capacitors and they are always crap.First thing that you guys should do is to replace them all but not with SMDs,get a normal capacitors same values.And of course replace all capacitos on PSU.Parts are cheap to buy about 30euros,work on the PSU is easy,only the VPB is tricky but it can be done.It only takes time but belive me don't even think of board replacament its cheeper to by a new set
Jan 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Pd46c10 daewoo plasma
I have a DAEWOO PD46C10 recently it would come on display a beautiful picture play for 10 minutes and the screen would go black.After several minutes reset turn it on and the process starts again.Whats the problem and where can I get it repaired???????????
Nov 25, 2007 | Televison & Video
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computers & Internet Logo
Top Daewoo Computers & Internet Experts
John Anderson
John Anderson
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
