Question about Hoover AAA140 Front Load Washer
Hoover AA Special Edition 1400 HPB 145 boil washes everything!
No matter what programme I select on my Hoover AA Special Edition 1400 HPB145 it seems to want to do the hottest longest wash only. This is getting expensive in shrunken/dyed clothes! On the odd occasion it doesn't boil wash it just does something else equally random and unprogrammed. The machine is around 3 years old.
Is it worth a repair or should I buy new?
gittos73
  • 244 Answers
SOURCE: hoover HPB145 washing machine is
if the spring is not on this is a problem due to the tub will bang around and will do more damaged which will end in the washer having to be replaced if the spring is broken then replace this item a.s.a.p peter
Posted on Jul 21, 2008
tborn6
  • 700 Answers
SOURCE: Bearings on Hotpoint
the unit is only 18 nmohths old then what you need to do is contact the manufacture and explain to them what is happening and if they are having simuary isssues with that particular moidel number. Possibly they are and you may be able to have it repaired on their dime! 18 months is not that long for a washer to start having these problems if you have not abused the unit by overloading the washer or over filling it with soap. Good Luck
Posted on Jan 05, 2009
  • 736 Answers
SOURCE: BURNING SMELL COMING FROM MY WASHING MACHINE
if it smells like rubber burning then i would suspect a belt is worn or slipping or somthing has jambed the basket from turning .. the belt is not expensive ..labor of course would be extra .. if the burning smells like insulation or a strong electrical burning smell then you may have a bad motor .. those used to be about $70 + labor .. no telling what they get for them now ...
you mention that the smell came from inside ... do you mean inside where the cloths are (the tub) or inside the cabinet (outside of where the cloths are) ...if the smell was coming from inside the washing tub .. then i would suspect something cought between the inner and outer tubs .. if the smell is not from there then the first suggestions above are good ... bras and slippers and such are good for getting cought .. check where the movable tub (with holes) meets the outer tube (no holes) .thats at the very top of the tub .. ..make sure nothing it cought there ...
Posted on Aug 05, 2009
  • 26 Answers
SOURCE: WATER LEAK ON REAR OF DRUM AND EXCESS MOVEMENT hOOVER1400 HPB145
If there is water leaking then you need to repalce both bearings and the seal that sits around the drum shaft and protects the bearing. Check the brass collar on the drum support thats sits in the bearing is not worn or grooved.If it is the shaft and/or the drum need replacing too
Posted on Sep 22, 2009
beltronic205
  • 1474 Answers
SOURCE: I need instructions for wool programme from my
Check the website/ good luck
Posted on Oct 01, 2009
How do I cancel wash programme on hoover optima7kg iv put wrong wash programme on but I can't seem to cancel it
I would suggest that you turn the programmer to the stop position then leave it for a few minutes and then reprogram.
Oct 06, 2016 | Hoover Washing Machines
Tip
Hoover Optima 1400 A+aa
if your Hoover washing machine is giving program problems,before you call a repair man, if the program knob can be pulled off, revealing contacts, get yourself a can of servisol contact spray, and spray and leave a few minutes, than wipe with clean soft cloth, you might save yourself money, unlike me, it cost me 120euros for 5 minutes of the guys time, and I had the Servisol in my workshop.
on Jun 01, 2012 | Hoover Washing Machines
Hoover 1400 AAA washing machine tripping house fuse
Possible that the control panel is short and so is tripping the fuse. Remove the connection to the panel and check if there is short , also remove the motor and check and this can confirm the case.
Jul 03, 2012 | Hoover Washing Machines
Hi im strugling to get the hoover special edition se 148 8kg 1400 AAA user manual and need assistance finding it
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 22, 2011 | Washing Machines
The dishwashing liquid has gotten thick in my ge dishwasher. The dishes are not getting clean. How do I clean out the dishwashing liquid resevoir?
Try running the hottest, longest programme WITH detergent but WITHOUT dishes. If you usually wash just a few dishes on a short programme, you might find that the machine never gets hot enough to wash away all the detergent residue.
Oct 09, 2010 | GE Dishwashers
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Aug 05, 2009 | Washing Machines
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Feb 26, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Hoover HPB145 washing machine is dented above the door from the inside outwards. Is it possible a drum retaining/suspension spring has become detached?
Jul 20, 2008 | Hoover Washing Machines
Hoover AAA140 Front Load Washer Logo
443 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
