Question about Lexmark X2650 All-In-One InkJet Printer
Paper feeds croocked
I tried disconnecting the printer. but that didn't help
5 Suggested Answers
  • 12 Answers
SOURCE: printer wont feed paper says out of paper
you "may" have something stuck on one of the feed rollers - a ripped piece of paper or something. See if you can examine the rollers, and look very carefully, particularly on the side that the paper keeps jamming.
In all honesty though, printers are pretty disposable these days. They're not worth getting fixed, and if you can't do quick maintenance on them, getting a new one is your best solution.
Posted on Mar 19, 2009
Printtech
  • 1087 Answers
SOURCE: Lexmark 1270 paper feed problem
It seems you're having mechanical problem with that spring disconnected somewhere in the printer paper feed. Honestly, mechanical problems in the printer is difficult to troubleshoot/repair. I hope I can assist you more on this but I advise you to contact Lexmark at 1-800-LEXMARK(1-800-539-6275).
Posted on Apr 27, 2010
SOURCE: LEXMARK X5450 PRINTER--PAPER WILL NOT FEED INTO PRINTER
i need a solution to get out of my lexmark x5450
Posted on Jun 09, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark X85 won't feed paper. When trying to
    There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
    1. Remove the sheets of paper from the feeder.
    2. Grab a flashlight and look inside for any debris.
    3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
    4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
    5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
    6. If cartridge area is clear, close the cover.
    7. Unplug and re-plug the printer into the power outlet to reset it.
    8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
    ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
    7. Close the printer cover and check for any errors.
    8. If no error appears, reinsert the other cartridge. Close the printer cover.
    9. Replace whichever cartridge is causing the error to appear with a new cartridge.
    Posted on Aug 03, 2011
    My printer is only pulling the paper in from one side, have tried cleaning the rollers and have checked for foriegn objects in the paper feed, display reads no paper, any ideas?
    My problem too, solved it easy, couldn't believe it, a pen had fallen in the paper feed slot, I didn't think it possible, couldn't see it until I took it to bits, be careful but worth a look
    Sep 23, 2012 | Canon PIXMA MX310 All-In-One Printer
    Tip
    Does not feed paper
    Follow the instructions below in an attempt to resolve the issue you are experiencing.
    1) Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
    2) With the printer off, check for any obstructions such as torn paper or foreign objects.
    3) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
    4) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
    5) Turn on the printer (still disconnected from the computer) and try to feed paper manually (using the paper feed button).
    Still does not work ? Go for Warranty or Service.
    on Aug 29, 2008 | Epson Stylus C88 InkJet Photo Printer
    Printer wil not feed paper in -keeps trying but paper will not move in.
    Hi Jamieos,
    Turn the printer off and on.Solved?
    Turn the printer off and disconnect from PC.Unplug from power.Reboot the PC.
    Remove the papers from the feed tray and look through the paper path for any obstructions.
    Load the print papers and make sure they are correctly aligned on the feed tray.
    Cear any print queues on your PC.
    Connect everything now and start the PC.
    Try printing.
    Hope this helps.Thanks!
    Please rate this answer.
    Dec 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
    Paper won't feed through to the printing area
    If when you mash print and the paper doesn't move through to be printed on it may be because you don;t have the paper inserted properly or maybe someone jammed your printer and tried to unjam it the wrong way and didn't tell you....hope it helps
    Nov 16, 2011 | Office Equipment & Supplies
    Paper feed rollers feed sheets croocked or not at all.
    Hi!
    Turn off the device. Check for any obstruction where the paper goes in and in paper tray area.
    Hope this helps
    Dec 05, 2010 | Epson Stylus Photo R300 InkJet Printer
    Epson workforce 610 prints croocked
    I would try holding the printer upside down and gently tapping.
    There maybe something stuck in the paper in slot
    Aug 02, 2010 | Epson WorkForce 600 All-In-One InkJet...
    The paper feeder is not feeding the paper correctly.
    Ok Try this Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
    And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
    Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
    That is where you'll find the print head assembly parked on top of it.
    It also has an electrical pump to milk the print heads and test for ink flow.
    So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Mar 31, 2010 | Canon PIXMA iP1600 Printer
    Computer keeps saying "paper out" or "not loaded properly"
    disconnect the printer from the computer
    do a manual paper feed
    if it can feed paper, replace usb cable or try another usb port
    May 14, 2009 | Epson CX8400 All-In-One InkJet Printer
    Paper jam
    i would Isolate the printer to know if the printer is getting
    the error stand alone. Disconnect printer from pc and turn the printer off. take out any remaining paper. Check for small pieces of paper and look for obstruction inside the printer and the paper feeding area. Then try and do a stand alone nozzle check by holding the paper button down and turning the printer on keeping finger on the paper button for arounf 5 sec. now if that still doesnt feed the paper there could be something worng with the machine. hopefully your still under warranty.
    May 06, 2008 | Epson Stylus Photo R220 InkJet Printer
    Lexmark X2650 All-In-One InkJet Printer Logo
    15 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
