Question about Beko Wm & Wma Models Washing Machine Motor Carbon Brushes
Is there a filter
There is no small door at bottom my machine it is like a long strip, how do I find the filter for cleaning ?
  • 3 Answers
Usually you can remove the kick strip by putting a small screwdriver in the gap and levering the panel off to find the pump filter behind
Posted on Jul 29, 2014
Blue cleaning light came on; how to I fix this
If it is on a washing machine run a cleaning cycle and clean the filter normally in the front of the machine. It is behind the small door at the bottom. Be sure you have a small bucket to drain filter in as it will still have some water in it. Hope this helps.
Nov 10, 2015 | Dishwashers
Fowl odor in front loader
Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
Feb 13, 2011 | LG WM-2277HW Front Load Washer
Hi, I have a Fisher Paykel DD603I (integrated) dishdrawer unit. The bottom drawer soap dispenser has water in it after it runs (and leftover soap), and there is a small amount of water sitting in the...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 16, 2011 | Fisher and Paykel Dishwashers
Machine states the filter needs to be cleared but i cannot locate it.
It is easy to clean it if it is front load there will a small door will be present at the bottom corner of the front door just open that door and one lever will be present just pull that then you can rotate the plastic knob in anti clockwise it will come out just clean the plug filter then refix it properly
May 16, 2010 | Washing Machines
I need to clean the filter of my LG WD-10112FD Washer Machine, but I don't know where is located, can you please help me?
Pump filter is behind access door or plastic kick strip at floor level on front of the machine. Make sure you drain the machine first because all the water in the machine will drain from here. Unscrew the plastic inspection plug and clean. Also make sure that there are no small objects like coins lodged in the impeller. It can help if you can lean the machine back against the wall..Not so far that the back feet can slip.....Nomess
Apr 06, 2010 | LG Washing Machines
Hello, I get a E:13 error code and the door will not unlock. Any ideas?
On the bottom right there is a round door with a small hole. Insert a small rod and push slightly, you will feel a spring action, then turn to the side and the door will come out. Inside you will see a large twist handle ( this is the clean out for the water pump) THERE WILL BE WATER THAT COMES OUT, BECAUSE YOUR FILTER IS PROBABLY CLOGGED, THAT IS THE E-13 CODE) Remove the door, clean the filter, clean up the mess and this will probably fix the problem.
Oct 10, 2009 | Bosch Nexxt 300 Series WFMC2201UC
No spin E20 alert on washer
clean out filter (small door front bottom right, then unscrew filter and clean it)
Oct 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Code on display OE
Just got the same problem. Found out there is a filter on the bottom of the machin that collects everything. It was plugged bad. There is a door on the front bottom left open door unscrew filter (the bigger object in the door.) Clean filter and wala.
Oct 24, 2008 | Washing Machines
How to clean the bottom filter
Don't know how old your machine is but on my wtl5400 the bottom flap is opened by:
1. open the drier door
2. note small round button on the lower right hand side of the drum surround
3. press the button which will spring forward then
4. lower filter cover springs off giving acess to filter drawer
NB if the filter is over full the button will spring open itself as a gentle hint
NNB YOU CANNOT CLOSE DOOR WHILE THE BUTTON IS EXTENDED so take care door will only close when lower cover has been correctly replaced relocating the button flush with the front of the machine
Aug 28, 2008 | Bosch Axxis WTL 5400 Dryer
Beko Wm & Wma Models Washing Machine Motor Carbon Brushes Logo
56 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
