Question about Smartpool Nitro Robotic Cleaner and Caddy
My light is red on my smart pool pump - Smartpool Nitro Robotic Cleaner and Caddy
Motor red error light comes on, pump won't turn on
if power to motor bad pump motor if no voltage to motor bad relay
Mar 01, 2015 | Marathon Electric Marathon imPower...
Pool pump would not start , flashing red error light
Could be many different things. Shaft locked up? Low voltage? Bad start relay. Bad start windings. Red light signifies what? Have an operators manual? Hard to say at a distance.
Dec 03, 2014 | Pool & Spa
Is it ok to drain an in ground pool
CAUTION !!! WARNING !!! some pools are next to the water table and will POP out of the ground. no joke and not cool.THEY FLOAT LIKE A BOAT most pools have a plug in the main drain and will need a pump placed on it to pull the water from around the pool out of the ground for SAFE POOL REPAIRS !..any lakes around you ? this can help you judge your water table in your area.. THAT being said if you know your high and dry .. suck away..
I\'M GLAD YOU ASKED. SMART !!
Jay.. the pool pump (doctor) motor repair guy in longwood Florida 32750
Jun 04, 2013 | Pool & Spa
How to wire the Aux 1,2 & 3 relays for Blower, spa light and pool light.
which ever you have wired to each relay connect the correct relay red and black connector then go to system setup and assign the aux and name them
Oct 24, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Can't turn the unit on.
Does your power supply have the fuse on the back of it? If so, check the fuse. If not, send it in for warranty service using our dolphin service form at www.arrowpools.net.
Jul 14, 2009 | Smart Pool Inc Dolphin Diagnostic...
Smartpool Nitro Robotic Cleaner and Caddy Logo
55 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
