Question about Bosch Washing Machines
How do i remove flap above detergent drawer of bosch washing machine
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
MNTECH
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
SOURCE: Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Posted on Jan 26, 2009
  • 9 Answers
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
Posted on Jul 27, 2009
Conditioner staying in draw and filling with water, have cleaned holes above??
You need to remove the drawer by pressing down where the softener flap is (middle) and pull it out of tray holder...then with a qtip or old toothbrush clean all parts after you pull the hinged middle flap all the way up to gain access to the bottom tube which has probably filled with gunk.make sure the top tube on the hinged part is clean too then bend it to fit over the bottom tube and clip closed.slide drawer back into dispenser housing.
Dec 07, 2014 | Bosch Washing Machines
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
Suds leaking from detergent drawer on brand new Bosch washing machine
Use high efficiency detergent that s more concentrated. It uses MUCH lesser detergent VoLUME than conventional. The detergent has "He" letter on the bottle. And usually with FULl load it uses only about 150+-cc ( my cup is on 3marked level provided by the detergent bottle) Hope this helps! Robert Calgary, AB
Dec 13, 2013 | Bosch Washing Machines
Why does the conditioner drawer not empty
If you remove the drawer and pull up the flap that has 'max' written on it, checked that the two cylinder parts are clear, especially the larger of the two as the fab cond and water are drawn up the side of these when they are together by capillary action (make sure when you close the flap down the large cylinder sits over the small on and the whole thing clips into the main body of the drawer). While you have the drawer out, look into the top of the dispenser housing (in the machine) look in the middle above where the fab cond chamber would be if the drawer was in, you will see four small rectangular cut outs, this is where the water flows during the final rinse. Get a medium size cable tie and push it through each of the holes, giving it a wiggle as you push it in (if the cable tie is long enough you will see the end appear at the back of the chamber). This will clear the channel of gung. Replaced the drawer and run a rinse cycle. This will send water through the channels to flush them completely. Hope this helps
Apr 09, 2013 | Bosch Washing Machines
Fabric conditioner section in draw always full with water after cycle has finished
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
Jan 15, 2011 | Bosch Classixx WFC 2465 Front Load Washer
WFD2460 Bosch washing machine
WFD2460 Bosch washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Scum (greasy dots) left on clothes
Try washing just an old dish towel on the hottest program, with 1 cup of soda crystals only.
Before starting this though, remove the detergent drawer, and clean it in hot soapy water. Spray a general surface cleaner into the drawer appature, and clean out as much as you can reach with a small cloth. Put drawer back and, put 2 tblespoons of soda crystals in the detergent section of the drawer too. Wash on hot.
These are mostly caused by a build up in the dispenser drawer.
Nov 05, 2008 | Bosch Washing Machines
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Open Questions:
Bosch Logixx 8 washing machine Powers OFF itself when filling water in the softening stage I have a 7 years old Bosch WAS32742AU/08 washer, it will wash, rinse then will power itself OFF with nothing on the display when it reaches the softening cycle where it begins to fill water, there is about 10mins left in the cycle. I can turn the dial OFF then back to the same program to resume the cycle, it will start filling with water again in the softening stage and power off again. I've checked the water level pressure switch hose and cleaned the chamber, I dont't think there is a problem with that because it works during the cycle until the softening stage. I can run and complete the Drain only cycle, Rinse only cycle, Spin only cycle and 15min Quick cycle without interruptions. It's only programs that has the Softening part of the cycle it powers off when filling water in the middle dispenser compartment during the softening stage where Valve 1 and Value 2 are open. I don't even use softener and the compartment is clean. The current work around is when it Powers OFF during softening, I turn the dial to OFF then select the rinse only cycle to complete the washing. I got into the Valve test mode and found that Value 1 and Valve 2 tests are OK individually but when it V1 and V2 are both ON to fill the middle softener dispenser compartment it wont stop filling and eventually the machine powers off. I posted a video of the test here: https:/ / streamable dot com/n1gw6 https:/ /player dot vimeo dot com/video/264199360 Do you know what the problem could be?
Apr 11, 2018 | Bosch Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
