Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer i changed my ink cartridges now my alarm light wont go off and it keeps telling me the cartridges are not installed correctly but i have taken them out and put them back in 3 times. i have also switched off the printer and restarted it after each time i put them back in
Dno buy a new one lol
Posted on Dec 06, 2007
  • 328 Answers
Hold down the OK or Stop/Reset or On/Off button for a few seconds to reset the new ink levels.
Posted on Nov 04, 2007
Have just installed new ink to my Epsom Stylus sx215 but wont print, just blank pages
Ensure cartridge fitted 100%, and you have taken off cartridge protectors, but the Printer should tell you why it's not printing !
sound simple to replace ink cartridge, but it can be tricky.
s
Feb 14, 2015 | Epson Stylus Office Equipment & Supplies
Have hp 450c orange cartridge light keeps blinking checked all cartridges only black cant get ready light to come on 3x so light keeps blinking.took out black cleaned it but still wont blink ready
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 09, 2011 | HP DesignJet 450c InkJet Printer
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    Ink light keeps flashing -
    Have you made sure that you've taken the plastic strip off of the ink cartridge? I had this problem once and I then realised that i had forgotten to remove the strip covering the ink.
    Also, have you installed a colour cartridge? I have the same printer and it wont print unless you have both ink cartridges inserted and in good condition. (If you don't want to fork out for HP Original, I find that the Tesco Remanufactured versions work fine)
    Hope this helps.
    Joe
    Jan 01, 2009 | HP DeskJet 930c InkJet Printer
    Printer error
    I've encountered this same problem, it could be that the ink cartridges that you have installed in the printer are either running low or out of ink.
    I had the problem also and found that after I swapped out my cartridges with new ones that I purchased the blinking yellow light on the Alarm and the black and color cartridge.
    If you do not want to purchase new ink cartridges to correct the problem you can can open the lid to your multifunction and remove the ink cartridges and place them in separate plastic sandwich bags and take them to any office supply store; Office Depot, Office Max, Staples and tell an employee there that you have run out of the ink and that you would want to have the cartridges refilled.
    I actually went to an Office Max in Houston with my cartridges and they told me it would be cheaper to have them refilled than to purchase a new set of cartridges; that after I looked online and compared what they charged for new cartridges actually saved me $40 to have the one's I already had refilled.
    Nov 21, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Ink cartridge
    The real problem is that the waste ink tank is nearly full
    Correct code procedure for resetting the Canon MP370
    Reset Waste Ink
    1) Enter SERVICE MODE.
    By pressing the black button
    with the star (in a
    head ?) above it, followed by
    scan, copy, scan
    2) Select TEST MODE (press right
    arrow button 13 times).
    3) Select [8] PRINTER TEST
    4) It'll now say "- 8-2 +" press
    the right arrow key once
    to get "- 8-3 +" Hit ok.
    5) Select 0. [INK COUNT].
    6) Press the ok key.
    7) It should return to showing
    the "8:
    Printer Test - 8-3 +"
    8) Press the [Stop/Reset]key -
    black key with triangle and
    circle on it –
    (returning to the state of 3)),
    and then press the [ON/OFF]
    key.
    Good Luck and don't blame me if it
    goes wrong !!!!
    Now you can print again, but it has not solved your full ink-tank, that has to be solved in future.
    Theo
    Jul 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
    Ink cartridge light keeps blinking
    you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
    Jul 07, 2008 | HP DeskJet 940c InkJet Printer
    Printer Problems
    hi dear
    this the error code
    E9 The connected digital camera / video camera does not support Camera
    Direct Printing
    E14 The Ink cartridges whose destination are wrong
    E15 Ink cartridge is not installed E16 - Ink remaining is unknown
    E16 -E19 Failed to scan head alignment sheet
    E22 Carriage error
    E23 Paper feed error
    E24 Purge unit error
    E25 ASF(cam) sensor error
    E26 Internal temperature rise error
    E27 Waste ink absorber full or platen waste ink absorber full
    E28 Ink cartridge temperature rise error -
    E29 EEPROM error
    E33 Paper feed position error
    E35 15 USB Host VBUD overcurrent error - USB
    E37 17 Abnormal motor driver error
    E40 20 Other hardware error
    E42 22 Scanner error
    E2-2 No paper (ASF)
    E3-3 Paper jam
    E4 No ink
    E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
    or the ink cartridges are not installed properly
    E8 Waste ink absorber full, or platen waste ink absorber full
    First, download the software at http://www.box.net/shared/4yblbn34kg
    Secondly, to run the software your printer has to be in service mode. Do that by
    - unplug cable
    - press and hold "power" button
    - plug cable
    - press "resume" and release
    - release the "power" button
    At this stage, your computer will detect a new hardware
    Run the software.
    oke
    Oct 20, 2007 | Canon PIXMA MP160 All-In-One Printer
    Canon PIXMA  MP160 All-In-One InkJet Printer Logo
    71 people viewed this question
    old marine
    old marine
