How to Change programme on Bosch S6P1B dishwasher
3 Suggested Answers
SOURCE: bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Posted on Mar 27, 2008
BElectric
  • 1140 Answers
SOURCE: Hello I have a Bosch dishwasher model no:
Hello Zub,
It's most likely a fault with the control module or the drain pump. Please follow these instructions to detemine the likely cause of the fault and, therefore, what to do next:
1. Turn the programme selector to any wash cycle but don't press start.
2. Open the door and pull out the lower rack
3. If the washer is dry, pour roughly a pint of water into the sump in the bottom of the washer
4. Locate the float (the mushroom) and lift it . . .
When the float is fully lifted (about 3/4 of an inch) the drain pump should start and drain any water from the washer. This activates the anti-flood safety feature and the pump should continue to run as long as the float is lifted. The power supply to the drain pump bypasses the controller so this is the best way to determine if the drain pump is faulty.
If the water drains when you lift the float . . .
The drain pump is working but it's not receiving the signal to start from the controller during a wash cycle. It may be a wiring problem, but more likely that your control module will likely need to be repaired or replaced. These cost about £100 - if you replace it yourself.
If you can hear the pump humming but water does not drain when you lift the float . . .
There may be a blockage somewhere or the pump impeller may have jammed or broken away from the driveshaft. Try lifting and dropping the float rapidly about 10-20 times. Repeated stop/start signals to the pump motor can free a stuck impeller.
If nothing happens when you lift the float . . .
There is either no power to the pump motor or, more likely, the pump motor has failed. You will need to test the motor to determine whether or not it needs to be replaced. You will need a Torx T20 screwdriver or screwdriver bit to remove the kickplate under the door and an ohm / multi-meter to test the motor.
The drain pump motor should give a resistance reading of between 110 and 260 ohms across the live/hot and neutral/common terminals if the motor is good. In most cases, the reading is about 160-170 ohms.
I'd suggest testing the drain pump using the float as detailed above, then let me know the results. I'm happy to provide further assistance once the likely cause of the fault has been determined.
Hope this helps.
Regards,
BElectric
Posted on Apr 10, 2011
Bosch SHE43MO2UC/48 - Dishes do not dry properly
rinse aid is required to aid the drying process either it is underdosing or the wash programme is too short temps over 55 degrees are needed for satisfactory drying result.
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Programme stuck on 65degrees.How can we change to using economy?
I believe you have a recalled unit, but to be sure cal Bosch's dishwasher helpline. the number is here in my guide for troubleshooting drainage issues.
Jul 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch exxcel programme runs until 1 min left and won't finish
This is a fault code which indicates it has not heated through the programme
Dec 13, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch builtin 60cm SGV4313 dishwasher
many thanks however intend purchasing new machine
Sep 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool ADG 957. Light for rinse programme on but start light flashing intermittently. Cannot change programme, cannot start machine.
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Aug 17, 2008 | Dishwashers
Bosch dishwasher model no SGS4002GB
Jan 09, 2008 | Bosch 24 in. SGS43C12 Classixx...
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
