Question about Beko Washing Machines
Hello all i have a beko DRVS 62W tumble dryer...it has recently stopped producing heat but still spins..how do i fix this please?
Hello all i have a beko DRVS 62W tumble dryer...it has recently stopped producing heat but still spins.i cannot find a reset button plus i have tried to find the test mode with no success.i have also cleaned all the filters..i need to get this machine working but cannot afford for an engineer (i am disabled on esa) any help and advice would be very much appreciated many thanks tracy
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
You are asking a subject which can be dangerous, since there is a gas chamber and gas involved. First check that no one has turned off the gas ballcock valve which allows gas to flow to the dryer. And that your main Home Heater or stove is working. Once you have established that, depending on model there should be an automatic ignition which lights the pilot. I'm not familiar with your model, but most dryers have a thermocouple which keeps the pilot lit. The auto reset should be near the pilot device. If you could look into Dryer by removing the access door, or sight glass (if any) you should be a pilot light or an activation of the light once the dryer request heat. As said I don't know your model, but look for a thermocouple, if you don't know what a thermocouple is, go to a Home Hardware or Appliance Repair Store and request a thermocouple. You are under no obligation to buy simple by becoming familiar. The problem with giving advice with gas appliances is that other items can cause the safety to be tripped. A crack in combustion chamber, a loose screw which changed the gas to air ration, the venting of NOX requirements. It will take some thought and knowledge, and physically seeing the devices, it could be just a wire which fell off the control valve. Ideally when it comes to gas you not only need the right tools, such as water & soap (which blows air bubbles the kids use) to check for leaks, but small wrenches, and perhaps a cleaning of the orifices. A stripped telephone wire works the best. Trace the wires from the area next to the pilot to the other end, the reset button should not be far away.
Posted on May 10, 2014
Testimonial: "the tumble dryer is electric...there is no gas involved at all (if there was i would not touch it).. the machine turns but produces no heat to dry clothes"
  • 2 more comments
  • Tracy Mccarthy
    Tracy Mccarthy May 11, 2014
    i have a strong feeling that the problem is the thermostat because the heating element turns on for a while and then cuts out.how do i find and fit this please?
  • deaususa May 12, 2014
    Your feeling may well be correct, I forgot to mention the most obvious.
    I forgot to sign in before finishing my answer. There should be 2 wires going to the Thermostat, follow the wires from the heating element. Or start from the heating control knob. Sorry I don't know your model. But since the burner does start it would take it out of the equation.
  • Tracy Mccarthy
    Tracy Mccarthy May 12, 2014
    thank you deaususa i am going to borrow or buy multimeter to check the thermostat and double check the heating element is ok and then i will know what i need to order to fix this problem..many thanks and hopefully i will have this sorted shortly
SOURCE: Dryer does not dry clothes
On the top of the heater box there is a thermal fuse that blows if the dryer overheats, on this model it could occur if the air circulation fan is faulty, or the condenser valve is faulty, alternatively the sump hose filter may be blocked, only a closer inspection of these items will determin which the problem is.
Regards
Advisor
Posted on Nov 17, 2007
SOURCE: Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Posted on Dec 26, 2007
  • 6 Answers
SOURCE: beko WMA 1715s - won't respond
door lock switch could be your problem..
Posted on Aug 30, 2008
SOURCE: Samsung washer P801 sticks/stops while
Hello Folks
When your front load washer starts to shake violently it is usually because the 2 shock absorbers are done.
Parts cost about $10 each. You need to take the top off the machine and the front. The bottom bolts are accessable from the front. The top bolts are harder to get at and a helper is very usefull.
Put a little blue lock tight on the bolt threads when reinstalling them.
Cheers
Bri
Posted on Apr 04, 2009
SOURCE: Bosch Exxcel Tumble Dryer lost manual, keeps
yes the bottom filter can be removed and washed out with warm water, this is the same problem we had
Posted on Jan 02, 2010
My dryer does not heat up but the drum is turning
Just because the drum turns doesnt mean its drying. The dryer has heating elements, sounds like they need to be checked or replaced. Check lint trap, and make sure no dust in the tube in back of dryer are clear. If they are it may be the heating elements.
Sep 13, 2016 | Dryers
THE RUBBER RING IS MISSING OFF THE WATER CONDUCTOR ASSEMBLY ON MY BEKO DRCT70W CONDENSER DRYER, WHERE CAN I GET ONE
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares www.espares.co.uk/search/mo1539505/tumble-dryers/beko/drct70w?page=2 Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK www.beko.co.uk/7kg-condenser-tumble-dryer-drct70-white
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares www.buyspares.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster www.partmaster.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay www.ebay.co.uk/sch/sis.html?_nkw=Beko+DRCS76W+Condenser+Tumble... Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' bekospares.co.uk www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/condenser... Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - mfg8a.probooks.no-ip.org mfg8a.probooks.no-ip.org/beko/beko-drct70w-manual.pdf time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • Amazon.co.uk: beko tumble dryer spares www.amazon.co.uk > Search > beko tumble dryer spares Amazon.co.uk: beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    Beko dcu9330w. Why isn't it heating?
    if everything else is working and spinning the drum
    door safety switch works
    faulty heater element is the most common cause
    that one does have an electronic control panel and timer
    might get that checked over at the same tine
    Jan 28, 2014 | Dryers
    Beko tumble dryer
    element and or thermostat...............cheers
    Jan 19, 2014 | Dryers
    Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
    hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
    Feb 08, 2011 | Dryers
    DRUM NOT TURNING ON BEKO TUMBLE DRYER. JUST OUT OF WARRANTY.
    Check your drum belt, sometimes this belt is broken or slipped off the motor pulley or idler arm pulley.
    Also could be a faulty motor..
    Another thing to try is to turn the drum by reaching inside of the drum and turning it by hand 1/4-1/2 turn with the dryer off. Then turn the dryer on again and see if it works.
    Motors will sometimes get a dead zone in them and this help move it from the dead zone.
    Sep 26, 2009 | Dryers
    Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
    go into service mode and reset
    to do this move to delicates turn on dryer and keep
    pressed down cancel button for about ten seconds release
    then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
    it is now reset, this worked for min a drcs68w
    Apr 23, 2008 | Dryers
    Washing Machines Logo
    138 people viewed this question
    Top Beko Washing Machines Experts
    Tom Chichester
    J D Wright
     Russ Hill
    Russ Hill
    Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
