Question about Toshiba e-Studio 205 Copier
There are ink smear marks on the top of the paper. They are about 1 inch square
2 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: toshiba 2060 marks on papaer
There is no such paper for copiers that I know of in 18 years. What you can do is try to run some blank pages throw the copier. This can tell 2 things if the line gets lighter in may be in the fixing ***'y and the upper fusing roller is shoot, needs to be replaced and or if it dose not clear up you may need a cleaning blade for the drum(OPC) and or the drum and blade as a set. It depends on how old the parts are? You may need to replace all 3 items and a general cleaning. Here is a idea for you are you running LTR or LTR-R you may be able to switch the paper arould to avoid the line all togather. Good Luck.... You may need a service call on the copier. With the age of the copier I might just go with the cheap fix first.
Posted on Mar 12, 2008
HP Lexmark 4050N Printer is smearing pages with faint ink mark.
This is more then likely due to an old or bad toner cartridge. Away for you to find out is to run a test print and if you listen close you can hear the paper advancing through the printer. It might take you a couple times but try to catch the paper at a point in the printing to where it would be just passing by the toner cartridge and ope the top cover. Remove your toner cartridge and pull the paper out. But becareful when pulling the paper out to not rip it or get toner on you. The toner has not yet been bonded to the paper yet until it passes the fuser at the back of the printer. If the paper shows the smear just after the toner cartridge then there is the issue.
Best of luck... And have a Happy and safe Holidays..
Dec 01, 2010 | HP LaserJet 4050n Printer
Ink from smearing all over my papers
Using original cartridges won happen like this.
May 30, 2010 | Canon Pixma MP450 All-In-One InkJet...
The paper comes out crumpled with smeared ink on one side
the problem is the fusing film of the printer. go to a store and try to change the fusing of your printer. sayedelyaskavesh@gmail.com
Jan 18, 2010 | HP LaserJet 1300 Printer
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
Hint:
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
Dec 02, 2009 | Zebra Eltron TLP 2844 Thermal Label...
I have phaser 8400 with 40k page count. I am getting a mark on page about 6 inches from top of page and 1/2 inch from left margin. Sometimes it is a faint blur 1/4 inch wide and 1 inch long. Other times...
Run Remove Ink Smears from the Troubleshooting menu. Try running the jetfix snippet found on Xerox website under downloads. It sounds like you may have a defective printhead telling it to spit out some magenta ink at the wrong time.
Jul 05, 2009 | Xerox Phaser 8400 Laser Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Printer leaving smear marks on paper
Are you using genuine Canon ink carts?? The cheaper "pattern" carts often use lower grade inks that don't dry as quick.
Also try feeding two or three blank sheets through the printer to clean the rollers and guides.
Jan 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Oct 03, 2008 | Lexmark C752 Printer
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Toshiba e-Studio 205 Copier Logo
19 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
