Question about Radio Communications
WHAT DOES RX STAND FOR ON A DIGITECH RADIA - Radio Communications
    Master:
  • 623 Answers
Receive. It means the radio thinks it's hearing an input signal.
Posted on Nov 07, 2014
What do all the instrument lights stand for on my kubota rx 302 mini excavator
kubota owners manual for rx 302 mini excavator pdf - P(1 ...
www.search-document.com/.../kubota-owners-manual-for-rx-302-mini-e...
Looking for: kubota owners manual for rx 302 mini excavator ... 3.4 Flow testing, regulating & setting the excavator OEM relief valve. ... of the parts, even those ...
Manual KUBOTA RX 302 - User's Guide KUBOTA RX 302 ...
www.manuals.club/results_alpha.php?search=KUBOTA+RX+302
KUBOTA > KUBOTA > RX 302 > 10 results for : KUBOTA RX 302 ... KUBOTA - KX 008 (KX008) Mini Excavator (User's Guide in French) · KUBOTA - K008-3 Mini
Oct 27, 2015 | Garden
I have a Digitech DC-1065 5watt 80 chanel radio. I can send but I'm not able to receive and have lost the manual.....what have I done need help to correct it
If you press the monitor (may be marked SQ) button while someone else is transmitiing and you hear them it probably means RX CTCSS is on. Use the menu button and then go up and down to find the RX CTCSS (TONE) and turn it off for rx.(recieve).
Sep 08, 2014 | Radio Communications
My digitech dc-1005 will sinc ok ,but one will talk and recieve one way but not the other way, has anyone ant ideas on what could be wrong with them,im thinking the rx or tx on one of them may be ********.
There are 2 oscillator circuits in each unit- one for transmit and one for recieve. It is likely the recieving section of the one that does not recieve the other is slightly out of tune.
Jan 25, 2012 | Radio Communications
Have a Digitech Vocalist II that stopped reading the midi chords transmitted by my keyboard. Checked midi cords, all settings (keyboard and harmonizer). And the inside of the digitech. It does not appear...
try a different signal source (tape player, cd player etc) and see if the sound gets into your device, if it doesn't see that sound either, then the problem is with the digitech and not your midi keyboard. The digitech doesnt have midi chords, just analog so I'm a bit confused when you say MIDI. I have the digitech vocalist IV and it doesn't have midi in or out either. only analog in, also two XLR's and etc. great machine by the way, I'm sorry to hear yours has quit working for whatever reason.
Mar 19, 2011 | Computers & Internet
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Rusty liquid under truck dripping when running sort of more than drip when turned off..not hose not radia. near end of hose opposite the radia..
sound like the water pump and you also need to flush and replace water with antifreeze even in summer because antifreeze has a lubrication factor and wont rust out all the components of the coolant system
Aug 15, 2009 | 1987 Ford Ranger
Code do radia renault megane 2006 15 dci
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also confirm the MAKE of CAR it is fitted into.
Jun 05, 2009 | 2006 Renault 181
Digitech RP250
you can download an instruction manual for free from here... I am sure that it will help you. http://www.devicemanuals.com/guide/Musical%20Instruments/DigiTech/DigiTech-RP250-English-User-Guide-TmpVeE16WT.html
or ask your question of this forum... i am sure they can help :)
http://www.digitech.com/soundcomm/new_account.asp
Dec 26, 2007 | Audio Players & Recorders
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
