Question about Kohler Generator 30 Kw Nat Gas Or Propane Indoor
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
    Prodigy:
    An expert who has answered 500 questions.
  • Kohler Expert
  • 573 Answers
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
Posted on Mar 02, 2015
2 Suggested Answers
  • 512 Answers
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
Posted on Oct 08, 2012
WHAT IS THE MOST LIKELY CAUSE OF AN AUXILIARY FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Check radiator coolant fill right to the top, if it has a low level switch or faulty switch I have seen this
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
Generator code 0094 01
Can you be more specific? what model Kohler is it, Model number KW etc.
Sep 15, 2013 | Kohler Electrical Supplies
Kohler 20kw RESA "invalid shutdown" fault
I have a Kohler 14Res and an error Invald Shutdown is indication and the engine is not crancking
Jan 30, 2013 | Kohler 20resa 20kw Home Emergency Backup...
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
After 8hrs of continous operation it shuts off and shows a aux/fault light on the display panel. Then has to be restarted and will run 8 hrs then trip again. The problem is it is a remote site so having to...
Aux fault is caused by a momentary loss of voltage from the speed sensor or low coolant level sensor. I would suggest you investigate both for possible cause.
If the unit has a low coolant level sensor you can find it near the top of radiator, small two wire plug. Disconnect and see if unit runs. make sure radiator is filled to over flowing before testing to eliminate this as the cause. Just because you can see or feel the coolant is not enough, fill to overflowing is the key.
Jan 02, 2011 | Kohler Electrical Supplies
Kohler Generator 30 Kw Nat Gas Or Propane Indoor Logo
867 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
