Question about Xerox Office Equipment & Supplies
Xerox 6204 black copy
I am getting black copy and prints on this machine
SOURCE: xerox xc1020
i need a xerox machine
Posted on Jan 03, 2008
  • 14 Answers
SOURCE: Xerox 6204 error 071-103
The cutter assy has a disk with hole in it to tell the circuit board how fast it is turning and where it is in respect to the home position. It may be that this disk or the sensor that looks through it has a lot of paper dust on it and not able to read correctly. It may me the the cutter itself is sticking and needs a little cleaning and oiling.
Posted on Feb 10, 2008
  • 10 Answers
SOURCE: Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
Posted on Dec 26, 2008
SOURCE: Xerox WorkCentre M15i squeals when printing and copying.
Do not only lubricate metal shafts, but promptly lubricate the "pulleys" on the right and left side.  the will look very similar to a wheek and pulley mechanism.  The squeal happens when one "bar" connects two "wheels" and one side moves faster than the other.
Posted on Jan 23, 2009
20YrsCompExp
  • 227 Answers
SOURCE: copies of xerox copier model 5201 almost black
USUALLY Black copies are a Drum grounding problem. I have not seen "black" copies due to old, bad, or otherwise inferior toner... Although, It is a Xerox, LOL
Posted on Apr 03, 2009
I am getting an error message "external device error" chain link 116-311 for xerox 6204 machine
"external device error" chain link 116-311 for xerox 6204 machine how to solve the proplem
Dec 09, 2013 | Xerox Office Equipment & Supplies
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Xerox xc1020
is it a printer/copier?
yes....do both prints and copies off the glass come out black?
yes...probably a problem in the drum/ CRU area
No- prints OK but copies black lift the lid and watch the exposure lamp...does it light up? does it move? Both of these scenarios would usually bring up a fault code, so I would still be inclined towards the drum unit.Pull the unit out and make sure no paper has sneaked up between the drum and the exposure slot, or even into the drum unit. another cause could be a broken corotron wire (very thin wire close to the drum usually behind a grid (charge grid) If it is a customer replacement drum unit (CRU) the charge grid will be built into the unit and will require the whole thing replacing.......
Dec 27, 2007 | Xerox CopyCentre C20 Black and White...
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
11 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
