Question about KitchenAid Refrigerators
How do i program a kitchen aid ref. mod. kfis25vxms2 all that comes up on display screen is PE0 000 ?
3 Suggested Answers
  • 9 Answers
SOURCE: compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
Posted on May 01, 2009
machinetech7
  • 1344 Answers
SOURCE: kitchen aid ref. KSRX22FNST01; ice maker; 120 v. at the IM connector, 32 V. at the IM motor
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
Posted on May 15, 2012
Broken magnet of a Kitchen Aid Blender. Where can I find another one? KSB5WH4
From Kitchen Aid they only come on a new motor. I am a Kitchen Aid service agent and I remove them from burnt out motors and keep them. Look for a service agent near you and see if they can help you out. I have no idea where you are, I'm in New Zealand.
Apr 26, 2016 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Program thermostat
You have to have blocklauncher tap the settings buttun at the top of the screen and then go on manage mods tap the mod you want to use then go back tap the settings then go on patched mods turn off safe mode
Nov 01, 2014 | Washing Machines
I just replaced the Compressor in my Kitchen aid Ice maker. Charged it to 6.2 pounds of pressure but kitchen aid will not give me the pressures it is supposed to be recharge to. Does anyone know?
Before you charge the system with R-12 freon you should check it for a leak, as with your ice maker it has leak that's why the pressure suppose to be is not reach. It also be clean by flushing R-11 into the system. If you have friend that has technical skill in ref repair ask for help. Better if you find the leak sealed it.
Good luck friend.
Jun 15, 2011 | Refrigerators
I have a Kitchen Aid KGRC608lsso, the key pad
I have the same problem with my KGRT607H. I took off the control panel, and wiggled some wires, then it worked (the LED display). Seems to be a loose connection, with one of the wires going into the connector. I myself haven't replace the connector yet, I just take the control panel apart, and wiggle the wires. Pain in the ****, so one day I will try to replace it either that or try to secure it better. My next step is to find out which wire leading into the connector. (figuring its either a bad wire). On my control panel, its the connector that has all the 'white' wires going into it, not the coloured ones.
May 20, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
Kitchen aid dishwasher with blinking lights. Manual says to call service tech.
and so you did / im a service tec . need more info th help . like mod and ( kitchen -aid ) . try looking in the front toe panel for a tec sheet this will tell you about the blinking lights and what the mean . get back with me if you need more help //mm fed back pls .
Dec 17, 2009 | Refrigerators
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
May 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Feb 26, 2009 | KitchenAid Dishwashers
Refrigerators Logo
18 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
