Question about Kohler Generator 30 Kw Nat Gas Or Propane Indoor
WHAT IS THE MOST LIKELY CAUSE OF AN AUXILIARY FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
    Prodigy:
    An expert who has answered 500 questions.
  • Kohler Expert
  • 573 Answers
Check radiator coolant fill right to the top, if it has a low level switch or faulty switch I have seen this
Posted on Mar 02, 2015
2 Suggested Answers
  • 512 Answers
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
Posted on Oct 08, 2012
Kohler 40EFOZD Auxiliary Lamp starts flashing After 2 minutes.
Make sure you have rated speed and voltage on the out put side.
Oct 13, 2014 | Kohler Electrical Supplies
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
Generator code 0094 01
Can you be more specific? what model Kohler is it, Model number KW etc.
Sep 15, 2013 | Kohler Electrical Supplies
Low water temperature/auxiliary light is flashing why?
Low water temp is because the engine block heater and/or thermostat has failed, or the outlet it is plugged into is dead.
Nov 20, 2012 | Kohler Electrical Supplies
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Kohler Generator 30 Kw Nat Gas Or Propane Indoor Logo
174 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
