Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
NEC NWTL 456 Error at Spin
After putting on a normal wash cycle, approximately 10 minutes into the wash, a beep comes on (quick beeps of about ten) then stops with an error E3 on the display. When I try again, it just doesn't want to rinse and spin properly. It's only under two years old. However, it worked after my girlfriend tried it so it works intermittently. It this a male problem or a known problem with the NEC washing brands. Cheers
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
SOURCE: beeping
Thanks! I found this online, which shows how to run tests on the washer to see what might be wrong, which helped, too. Now if i can just find a few muscly people to help me move the dryer from atop the washer.
http://forum.appliancepartspros.com/attachments/washer-repair/42d1194897506-error-code-01-wfk2401test.pdf
from this page:
http://forum.appliancepartspros.com/washer-repair/2385-error-code-01-a.html
Posted on Nov 26, 2007
dutchman05
  • 487 Answers
SOURCE: E3 error on NWTL 506
Hi that is for me a hard one as I think you are locates in AU but please sent question to HERE and they will answer it for you during office hours. No problem
Posted on May 13, 2008
SOURCE: bosch classixx6 1200 express
Turn Program switch to 6 o clock,hold RPM button turn switch to spin, release RPM button.Turn back to 12 o Clock .It should reset it ,Mine is a classicxx7 but should be the same...Marius
Posted on Jun 27, 2008
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
Atf7000es0
Good Morning John, thank you for allowing me to assist you! Here are some simple troubleshooting steps to help resolve this issue:
  • First, reset the unit by either unplugging it or flipping the household circuit breaker.
  • Wait approximately ten minutes and turn on the power for the washer.
  • Next, turn on your washer and select a normal cycle.
If your washer continues to beep, it could possibly have a defective control board or a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Oct 07, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire dryer model LEQ1442ES0 beeps then shuts off after about 10 seconds. Four lights blink 3 times. Error code for?
Hi Robert, thank you for allowing me to assist you!
Constant beeping is often an indication of a possible malfunction. Let's try reprogramming the dryer by either flipping the household circuit breaker off or unplugging it. It is important to wait approximately ten minutes and then turn the dryer on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error from the main control board, a potential wiring failure, faulty door lock assembly or the timer itself may not be operating correctly. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis.
Sep 01, 2013 | Electrolux EW1209i Front Load Washer /...
I have model LEQ1442ES1 and it beeps on the normal, high settings
Hello charityscrug - Try reprogramming the dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. Select a normal cycle and if issue continues then the dryer could possibly be experiencing a communication error from the control board or wiring failure. Contact a professional to move forward accurately.
Feb 11, 2013 | Frigidaire FEQ1442ES Electric Dryer
Flaching lights on control panel
Hello Robert Costain - Do you notice any error codes on the display or any audible beeps? Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. Select a normal cycle and verify if it will start. If it proves to be ineffective, the unit may possibly have a faulty door lock assembly, wiring failure or a communication problem with the control board. I recommended contacting a professional to move forward accurately and to properly assist with the repairs.
Jan 19, 2013 | Frigidaire FTF2140FS Front Load Washer /...
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
E3 error
looks like a heater failure it statrs to heat at about this time into wash mode.
Nov 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I can't change the default wash cycle without it switching
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Jan 28, 2009 | Kenmore Oasis HE 27082 Top Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
214 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
